vtec swap not working properly
Hello guys was wondering if you can help I did a vtec swap on my 94 accord out of a 95 what I did was take the head and connect the vtec computer to it and take the oil control orifice out I used the external coil distributor cuz it's the only one that worked and when I turned it on it revs all the way to around 4 and back down to one ccontinously can anybody tell me why it does that thx
Well when I swapped the head the intake manifold stayed in place I only disconnected one or two vacuums so I'm thinking it's got something to do with computer or distributor or something I really don't know
As stated it sounds like a vac leak.
If you are sure it is not from the gaskets (?), then check all of the vac lines coming off the intake. Also be sure the PCV is fully seated and the line to it is ok.
nanagsr
Feb 9, 2010 08:52 AM
POE
Dec 1, 2003 12:15 PM
