PA FS/FT 2000 Honda Civic SI EM1 J32A3 Swap
Means of contact: 717-385-9353 call / text
Price: $8,500 only trade for luxury car. TL, TSX, RL etc
Time has come to post my daily driver up for sale, time to build something new. Car is a blast to drive and a true sleeper. On with the details......
2000 Honda Civic SI
193,000 on body
74,000 on the J32A3 Swap
268 HP 240 Torque
~~~ASKING $8,500~~~~
Call or Text 717-385-9353 or pm me here
~Exterior~
Energy Suspension Rear trailing arm bushings
Karcepts front hubs 36mm with extended ARP studs
New OEM wheel bearings
New lower ball joints
Stainless brake lines front and rear
Password JDM Hood risers
Polished ASR subframe brace
Neuspeed springs
~Interior~
Acura TL shifter box
Acura TL shifter cables
Karcepts shift ****
Acura TL steering wheel
Headunit
Black carpet
~Performance~
2004 Acura TL J32A3 swap with 74,000 miles
6Speed Manual LSD Tranny
Hasport EKJ2 Mounts
OBD Welding works stiffened tranny mount
Ktuned Fuel pressure regulator
Walbro 255 fuel pump
Russell Fuel filter
RPM Systems Conversion harness Drive By Wire
3" Kteller V-band exhaust into a 3" Vibrant Muffler with custom turn down stainless steel
3" aluminum Intake
36mm axles custom made
VW tucked Radiator
Spoon Thermostat lower temp
Clutch slave cylinder delay valve removal
There is a Hole in the passenger side fender. The hole is from the custom turbo setup that I had built for the car. The car was never ran or started with the turbo setup on it. If someone is interested in the turbo setup I will sell it for a extra $5,000 on top of the car price. Its almost a complete kit. Would need injectors and clutch to run it.
2000 Honda Civic SI
193,000 on body
268 HP 240 Torque
~Exterior~
Neuspeed springs
~Interior~
Karcepts shift ****
Headunit
Black carpet
~Performance~
Hasport EKJ2 Mounts
Russell Fuel filter
3" aluminum Intake
VW tucked Radiator
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
wallsz40
Mar 17, 2010 09:06 PM
