Brake and Fuel Lines
I have a 96 accord, 5-speed, 190k. Both the brake and fuel lines rusted out right before the rear wheel. I am assuming the brake lines have to be replaced. I have never done this and am having no luck finding pre bent lines. I am guessing they do not sell them this way.
Do they sell brake lines pre bent? If not, I am assuming they have to be replaced from the master cylinder, all the way back.
Is it safe to splice in a new fuel line from a solid spot back using fuel grade rubber hose?
Might sell it at this point and get CRV.
Fuel lines are ~70-100 each(Vent, Return, Feed).
Good news is brake and fuel lines you need are the same on F22 cars ABS or non ABS.
Try a junkyard first if you do not feel comfortable bending/flaring your own lines.
