Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
07 sedan with two faulty srs modules?!?!?
Old Dec 22, 2014 | 11:38 AM
miravete's Avatar
Icon6 07 sedan with two faulty srs modules?!?!?
2007 sedan auto non K series
ok, purchased this car salvaged and need to pass the vin verification and with that, the srs light needs to be off.
did the code reading and got driver air bag, passenger seat belt, and passenger seat.
switched out the driver air bag, passenger seat belt, passenger seat, and srs module from a non wrecked 07 civic.
checked the codes, and now i get codes 8-1 and 8-5. According to the code readings, those are for a faulty srs module.
but another member did a trial test, and found that that codes 8-1 and 8-5 where when he disconnected the wiring under the passenger seat.
Anyone had any similar situations?
Do I treat it as a faulty srs module, or faulty passenger seat?
and here's the other fun part. If I put the old srs module back in, i get codes 5-1 and 4-2.
Old Dec 26, 2014 | 06:28 PM
vladd's Avatar
Default Re: 07 sedan with two faulty srs modules?!?!?
You need to have Honda reset the SRS computer (the new one). The diy method doesn't work on this gen of Civic.
Old Jan 21, 2015 | 08:55 PM
txaccord07's Avatar
Did resetting the SRS module solve this for you? I suppose, from other reserch, when you change the SRS module, it has to be re-calibrated to the passenger seat system. Are 8-1 and 8-5 an indication of needing such syncing?
Last edited by txaccord07; Jan 21, 2015 at 08:57 PM. Reason: subscribed to changes
Old Jan 22, 2015 | 09:32 AM
txaccord07's Avatar
Just as an update:
I had recently replaced the srs module on my '07 Accord, due to codes pointing to a faulty module. Once the module was replaced, I too was getting 8-1 and 8-5 codes, using the key/obdii jumper mode of reading the number of flashes. These 8-x codes were not present with the older srs module, but only showed up with the replacement unit.
Went in to the local Honda service center to get the system checked out, and it did show the OPDS and weight sensor codes. They re-calibrated the SRS module/OPDS system, and that took care of the issue. No more seat belt light, no more issues!
So, if you do replace the SRS module and you end 8-1 and 8-5, get the system re-calibrated.
Old Jan 22, 2015 | 12:01 PM
DaveSi677's Avatar
Good job vladd!
Old Jan 23, 2015 | 03:19 AM
vladd's Avatar
Originally Posted by DaveSi677
Good job vladd!
Thanks. I've dealt with this before.
Old Jan 23, 2015 | 06:36 AM
miravete's Avatar
txaccord07 is right,
if you get codes 8-1 and 8-5, you need to get the srs module reset, since those codes are for the seat sensors....
took mine in to the dealer, 30 mins later.....left with no srs light. !!
Angeles1262
Acura TL, RL & ZDX
Apr 24, 2017 11:09 AM
McCoy
Nov 2, 2014 03:05 AM
hoffdaddy
Sep 23, 2014 09:06 AM
BobWilson
Honda Civic (2001 - 2005)
Jul 24, 2007 06:07 PM
