Del Sol Overheating / blown head gasket advice requested
Old Dec 20, 2014 | 10:39 PM
ejv8s10's Avatar
Default Del Sol Overheating / blown head gasket advice requested
Hi guys - and Seasons Greetings!
Car: 94 Del Sol Si (stock) D16Z6/auto trans, 160,000 miles, bought 3 months ago for $1,600. Has rough body, no rust, good A/C, excellent brakes and trans. Driven on weekends to come home to Jacksonville from U of FL at Gainesville.
The car is my college student Godsons, bought because he likes my Del Sols. He is rich but financially prudent (a cheap SOB). He's brilliant, a inexperienced mechanic and a nice guy. Car repair training is my gift to him.
So far using my tools and guidance he has replaced spark plugs, a water pump, timing belt, cam & crank seals, thermostat, rear calipers and interior door handles. He did this with my oversight and tools. He follows directions well and is very quick to grasp ideas and repair techniques
Issue is chocolate-milk-shake looking oil. Car runs rough and loses water. I think a blown head gasket is likely. He is willing to work on the car at my place, with my tools.
Considering cost, materials and time required do I recommend:
a JDM engine or
replace head gasket or
buy a different car?
Old Dec 21, 2014 | 12:50 AM
Former User's Avatar
Default Re: Del Sol Overheating / blown head gasket advice requested
I'll assume the engine was severely overheated, so replace it or the entire car.
Old Dec 22, 2014 | 09:01 AM
Humphrizzle's Avatar
it's a blown headgasket. remove cylinder head, resurface head and block, install oem head gasket, 2 oil changes, coolant flush, good as new.
Old Dec 22, 2014 | 02:31 PM
NotARaCist's Avatar
I never narc'd on nobody!
Unfortunately, this is definitely a possibility. Since you only bought it 3 months ago, there's a high change that the previous owner fucked it up royally, used some stop-leak **** just to sell the car, and dumped it on the first sucker he could find, which was, unfortunately, you.
Pull the head. Have it professionally cleaned, pressure tested, and decked. Check the block deck for trueness. It will probably be warped. If it isn't, you got lucky, and should remove it and completely overhaul it, including a hydrosonic cleaning to get any **** out of the coolant channels. If it is, you got unlucky, and should remove it and completely overhaul it, including a hydrosonic cleaning to get any **** out of the coolant channels. Once you've done that, replace the radiator to get rid of any residual **** in that, and all of your coolant lines for the same reason.
See what I'm getting at, here? It's time for a complete rebuild under the hood.
Old Dec 22, 2014 | 05:06 PM
NotARaCist's Avatar
Not checking the block deck would be asking for trouble.
Old Dec 22, 2014 | 10:09 PM
NotARaCist's Avatar
It should be, but for the average DIY/shade-tree/back yard mechanic, it unfortunately isn't. For severely overheated engines, that 99% becomes more like 75%.
Old Dec 22, 2014 | 10:43 PM
tony_2018's Avatar
Fish Twig
Originally Posted by slomofo
That's part of a head gasket job, is it not?
We (mechanics) always check the block deck on cars that are getting head gasket jobs, but 99.9999999999% of the time the deck surface is fine. Moving into boosted applications, 7M-GTE Toyota Supras seem to be the only ones where that 99.9999999999% figure changes to a lower percentage.
For the novice, they wouldn't know. So when we tell them to do a headgasket job, that is all they will do. Even the backyard mechanic would not touch the block deck or the head.
Mastermind46
Jan 5, 2014 02:20 AM
mainehonda95
Apr 11, 2013 07:01 PM
Shaggibus
Oct 31, 2010 03:23 PM
