What to clean header with? (Pre-Install)
Old Nov 2, 2002 | 01:18 PM
xjohnx's Avatar
Default What to clean header with? (Pre-Install)
I'm installing my Type-One header tomorrow, what should i clean it with before the install to remove all the grease and oils from our hands so when the color turns, it turns evenly?
Old Nov 2, 2002 | 01:22 PM
Shark Tank's Avatar
Default Re: What to clean header with? (xjohnx)
isopropyl alcohol and you should use gloves when installing it to reduce the amount of oils that get on it from your hands, etc
Old Nov 2, 2002 | 08:55 PM
Art Vandeleigh's Avatar
Default Re: What to clean header with? (CART fan)
or just soap and water, that will do the job too. make sure either way to wear gloves, if you dont want your fingerprints burned into the header.
SiR-T
Oct 27, 2007 08:45 AM
Jaydeep
Jul 22, 2004 08:45 PM
APEX CRX
Oct 31, 2003 01:05 PM
JoshRambo
Aug 15, 2001 09:18 AM
