2007 Civic starts and immediately dies
Hey guys,
I have a 4 door 2007 Civic and last night out of no where the car wouldn't stay on anymore. It starts fine and then shuts off after two seconds regardless if I rev the gas pedal or not. Also all the lights in the cluster display are out!! The headlight, windows and some electrical components in the car work but nothing on the display, it's completely dark.
The car has 150k on it and gave me problem with the battery last week as it stalled and I had to get a boost. I then took out the battery and charged it with my Motorcycle trickle charger! It worked fine till last night. So when this problem happened I first thought there might be something wrong with the battery and I replaced it today but nothing changed. It starts and then the car shut off in a couple of seconds with the cluster light being out.
I did some research online to check if there's something wrong with my alternator, fuel pump or crank sensor but none of these explain the cluster display not turning on. So my guess right now is that maybe a burned fuse or the main computer?!
Any suggestions? Thanks
bobbyk
Honda Civic (2006 - 2015)
Dec 23, 2014 09:13 PM
Dramysx
Jun 18, 2008 04:16 PM
