Wheels Wheels and Tires
OH 5x100 - Ronal Racing Turbo's - 15x8 -Cincy,OH
Old Dec 19, 2014 | 05:42 AM
ohiodub_99.5's Avatar
Default 5x100 - Ronal Racing Turbo's - 15x8 -Cincy,OH
*Up for sale are my lovely Ronal Turbos. 3-piece, magnesium centers
Bolt pattern- 5x100
Diameter: 15in
width: 8"
Centerbore: 57.1
ET: estimated to be around +32-38ish
(pics will show fitment, in pics 3mm spacer front/ 5mm spacer rear)
2"-lips and 6"-barrels
I tracked these down from the ends of the earth a couple of years ago (really just from an atttic), split them down, had some damage on them professionally fixed and repaired. Fully polished all the lips, replaced all the hardware with allen-head, grade-12.9 bolts and stainless washers and nyloc-nuts as well (still have all the original bolts also).
Some chipping of paint on centers from road debris, as these wheels were designed to suck air in, subsequently sucking in road grit as well, i was going to refinish them, but now i'll leave the color choice up to the new owner....
I still have the 3 VIAL center caps that came with them, never could track down a 4th. I did end up buying some hexagonal style center caps to use, but they need some modifications to be made to fit correctly, they are just a few MM too small for the hole and need some material added to the prongs to get them to be secured... the center cap hole is an uncommon size so sourcing caps has been a nightmare. And i had some quality Ronal Logo decals made to fit them hex-caps also.
NO TRADES, Buyer Pays shipping/fees/insurance
Tires will be removed prior to shipping, and most likely will split the wheels down as well to make shipping as cheap as possible and minimize any risk for damage.
Asking $3500 ----- OBO.
* Yes, these are the same wheels you may have seen listed earlier as 5x98pcd. After posting them on an Alfa Forum, i was informed that with the center bore these are (57.1) there is no way that they could be alfa fitment (58.1/58.6 typical alfa CB’s)…. That lead me to do some extensive double/triple checking and measuring, using an old brake rotor i had laying around and came to the conclusion that these are indeed 5x100…(i was told 5x98 by previous owner, and it was so close to 5x100 it didn’t even bother me.. simple fix with wobble bolts.) Just wanted to clear that up a little bit.
more photos can be found here:
Ronals For Sale Photos by ohiodub_995 | Photobucket
Old Dec 22, 2014 | 09:38 AM
Default Re: 5x100 - Ronal Racing Turbo's - 15x8 -Cincy,OH
more photos added to album, updated.
Old Dec 25, 2014 | 09:20 AM
jdmfoose's Avatar
bump for the real deal! those are awesome!!! GLWS
Old Dec 28, 2014 | 11:36 AM
toyomatt84's Avatar
Sanji
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
raverx3m
Mar 4, 2013 04:20 AM
Scotland:EF3
Dec 25, 2007 06:36 PM
omehegan
Oct 31, 2005 12:58 AM
Type_RS_59
May 12, 2005 09:01 AM
