Big Turbo Partout
Most of these prices are already 50%+ off Retail. All Parts are like new and most parts come in their original boxes. I may negotiate on some things.. PLEASE DO NOT try to bring down the price by saying "can you sale it w/out that"... If anything says it "comes with" something...Then it comes with it! Those things are custom to those pieces...
Bottem end B18c $3200; Darton Sleeves 84mm, JE Pistons, Upgraded Wrist Pins, BC Pro Rods arp625, Calico Bearings, Gsr Crank, Moroso 5.5 Oil Pan, ATI Street Damper, Arp Pulley Bolt, New Oil/Water Pump, New crank Sprocket/guides, all new seals, Arp main Studs/Align honed w/head torqued, roughly a 10.5:1 Comp motor, ocd balanced rotating assy .0010/gram,P2W Clearence .0035, Main bearings .0015", Rods .0018" +/-.1 All parts rated over 300hp per cylinder and NOT a smoker engine:-)!
Head 80miles $1300! ; Ported to i'd say a stg3 on the exhaust, combustion chamber work and some work done on intake ports. All new bronze valve guides, all new seals/orings, 3angle valve job then, lapped in 3stages(engine sealed perfectly), BC SS Valves 1/2 over, , BC 0010 Spring/retainer kit with cnc machined keepers, BC stg2 NA Cam was Degreed for boost, GE Cam Gears, GE Cam Seal, Shaved Vtec Solenoid, Speedfactory Titanium Lock Kit, Stock Rockers lightened 240g total and finished with a Shot Peen.
Gates gsr Racing Belt Part# T247RB $40,
Bseries IAC Valve painted.. $40
Custom ARP2000 Material Head Studs.. These are not your basic arp head studs. Rated at I believe it was over 320,000psi and good for 60psi+ boost pressure $140
ID2000's $650 Pickled everytime, in original box, special Seals included.
Skunk2 lma's for Bseries engines $50
AFI FF Manifold Twin Scroll $950, comes with wastegates hardlines and -10 Oil Return/Turb Fitting, Mac Solenoid and Hard Plumb LInes and all 3 up Pipes
CompTurbo CT43 6767 .90 a/r Triple Ball Bearing $1250, comes with Velocity Stack/Screens and -3an Oil Feed line.
Two Tial 44mm Wastegates $350 for both or $200ea. Will offer package deal if purchased with Manifold setup... Original Boxes
Tial 50mm Bov clean, comes with hard Vac Lines and Fittings $150 Original Box.
Aluminum Polished Charge pipes 3" really nice setup on mine. Will definitely require fab to work on your setup, there is almost always fab required...$50
GsR LSD Trans all new Gearspeed bearings/seals/synchro kit, new 3rd gear set+miscellaneous stuff/seals $700 spent some time ocd shimming this thing it shifts nicely!!
Clutchmasters FX725 Multi Disc $575 60% life left
Bseries Shift linkage $30
Skunk2 Radiator, bracket and fal fan setup. Badass fan/shroud setup $250.
Comes with Hoses.
New Autozone Starter $40
OEM Alternator $20
AlterStart 170amp HI Output Alternator 80miles $150 In Original Box
Aem 30-1050u v1. It's latest version of the v1 this system ais tons of fun!!! $500. Comes with obd1-obd2b Jumper Harness and blue powder coat glove box mount
Aem Twin Fire CDI Ignition $275 comes with coil wiring harness and battery location stand bracket. All AEM Stuff Comes in original Boxes w/Instructions
Aem Epm Module $220
Aem CDI Pencil coils x5 $180
AEM WIdeband 30-4100 $110
Aem 30-2050 EGT Kit bnib $130
Aem 3.5bar Map $70
Avid Bseries-eg Motor Mounts $150. Rear mount is Solid.
BNIB Lower Trans/Engine Damper Mounts $10
MBC/Xenocron Cam degree FIxture Kit $150
Vtec Solenoid x2 $30ea
Moroso Radiator support(for radiators that sit lower than stock) $10
Comes with Hoses.
OEM Alternator $20
Aem Epm Module $220
Aem 3.5bar Map $70
Sorry guys i'll have to modify what i'll sale online and repost at a later time.
I can't ship this stuff across Country and then have a Paypal Claim stabbed up my *** for missing a small detail.
NO SALES. Thread/done....
CaseBone
Dec 26, 2007 08:06 AM
