99 Civic LX/D16y7 - high idle problem
SOOOOooooooooooooo I bought a new D16Y7 off a guy, a good guy i think. anyway after i got it into my civic and got everything hooked up, i crossed my fingers and started it up. It's not idling, it just revs endlessly...... Please if anyone has anything please let me now.
So once i got the engine mounted and hooked up i started it and it doesn't idle, instead it revs continuously... its reved above 6k rpm and i shut it off so i don't blow my new engine. I've looked into the throttle body, intake, IACV, everything and nothing has fixed the problem. I hooked up my scan too and got the code P1509, which is IACV circuit failure.
You have a massive vacuum leak somewhere. Why are you swapping a Y7 into an EX? Are you swapping the complete long block, just the short block, or what?
Me, and everyone else, is saying that the Y7 DID NOT come stock in any EX trim level so it pretty much sounds like you're putting the wrong engine into that car.
If not assume it was done wrong and redo the wiring and check ecu.
Thus info is important as we can not help you without knowing this information as the car did not...notnotnot come with that engine from the factory
This tells me you don't know what car you have. Which means WE don't know what car you have and therefore cannot help you effeciently, if at all.
