NJ 1991 Automatic RT4WD W/ Mini-me Swap - $1800 Firm
Up for sale is my Rare Automatic 1991 Honda Civic Real Time 4wd Civic Wagon aka RT4WD. It currently has 155K+ Asking price is $1200 Firm. ***Car has to be towed at the moment***...see below
No Trades please....Cash only!
Call/text Eric 973-417-4742
Some Cons.
-Low compression on 2 Cylinders. Must tow home!
All the Pros
-Head was swapped with a D16y8 Vtec Head(aka mini me swap) Head was previously serviced before being put on(Guides, seals, valve job)
-New Honda OEM Head Gasket
-New Honda OEM Timing Belt & Seals
-New Honda OEM Water Pump
-New Bisimoto Intake Manifold Gasket
-New ARP head studs
-New NGK Spark Plugs Wires
-New NGK O2 sensor
-New Radiator
-New Battery(still has warranty)
-New Distributor and cap/rotor
-2 1/4 Custom Exhaust Piping with Vibrant Exhaust & magnaflow (*Not loud at all, stock sounding with a nice deep rumble)
-Ice Man Short Ram Intake (Stock intake is also available)
-New Valve Cover and Seals
-New Bosch Alternator
-Tranny Fluid was replaced with OEM Tranny Fluid only
-Apexi Vafc is connected and currently running VTEC.
-Painted and cleaned Valve cover
-New Hood Latch Cable
-Front Winter Tires(Studded)
-Original White RT Rims
-Car does have automatic starter but is not connected since the VAFC is connected at the moment.
*Note all Engine Work was done and installed by Custom Car Performance by Rob in Rockaway, NJ if you would like to know more info.
Price is $1200 Firm! No Trades. No I will not deliver or drive to you so please do not ask.
Please Email, Text, or Call anytime show contact info .
Thank you!
Some Cons.
All the Pros
-New ARP head studs
-New NGK O2 sensor
-New Radiator
Thank you!
JDM_FRONTIN
Apr 11, 2006 09:44 PM
MilanoRed EG6
Aug 13, 2005 05:46 AM
