1995 honda civic crank but doesnt start!!!!
Old Dec 15, 2014 | 05:42 AM
Egkid95's Avatar
Default 1995 honda civic crank but doesnt start!!!!
I have went thru all test I know and no luck. I have yet to replace my distributor and fuel filter, that's coming next week(hoping that's the problem). I just did a tune up with ngk products. wires, cap, button, spark plugs, air filter. please help. thanks
Old Dec 15, 2014 | 06:00 AM
09chaplak's Avatar
Loves Tossing Salad
Default Re: 1995 honda civic crank but doesnt start!!!!
What are these tests you speak of?
Old Dec 15, 2014 | 06:38 AM
Egkid95's Avatar
I checked my fuel pump relay.
I checked all wires and plugs.
I check the fuel pressure.
Old Dec 15, 2014 | 06:44 AM
angrysmileyface's Avatar
Whats the color of the spark you're getting? Is your fuel fresh or stale?
Old Dec 15, 2014 | 07:02 AM
Egkid95's Avatar
well i don't have a spark plug tester. i just sprayed starting fluid in my intake hose, the car still didn't start, so Im guessing its the spark plugs failing to get spark. i have brand new NGK spark plugs and wires also just the cap and button. i didn't replace the distributor yet.
Old Dec 15, 2014 | 07:12 AM
09chaplak's Avatar
Loves Tossing Salad
What engine are we talking about here? Regardless there are 4 things needed for an engine to live.......https://honda-tech.com/honda-civic-d...2A%2A-1992733/
Old Dec 15, 2014 | 07:32 AM
Egkid95's Avatar
d15 b7 non- vtec
Old Dec 15, 2014 | 07:51 AM
09chaplak's Avatar
Loves Tossing Salad
Did you find your way to the link I had in my last reply? That should help you out with your problem.
Old Dec 15, 2014 | 08:10 AM
Egkid95's Avatar
yes! thanks a lot, that really did help me out all the way. really nice right up. I think if ya just post that up it can help anyone with this same issue. once again thanks.
Old Dec 15, 2014 | 08:30 AM
09chaplak's Avatar
Loves Tossing Salad
No problem, but I won't take credit for anything written in that write up haha because they are posted for everything to take a look at. If you go to the top of the forum section you'll see these grayed out threads called stickies. The FAQ is where all the posts can be found on numerous problems...https://honda-tech.com/honda-civic-d...tions-1998336/
So next problem you run into, I would start here first and then post if you can't find the answer in there or anywhere else on the forum.
Old Dec 15, 2014 | 09:33 AM
Egkid95's Avatar
ok, noted. thanks
micah13x
11
Apr 14, 2011 03:09 PM
hey man
Jan 10, 2011 02:28 PM
dth0ng69
Oct 10, 2010 08:26 PM
honda20crx
Apr 19, 2010 12:51 PM
