Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
'04 V6 MT6 clutch/gearbox trouble
Old Dec 13, 2014 | 05:08 PM
neoteny's Avatar
Default '04 V6 MT6 clutch/gearbox trouble
So I've picked up this '04 Honda Accord Coupe 3.0 (J30A4) V6 MT6. The engine is amazing; I'm very much impressed -- this is exactly what I was looking for.
But when I do power shifting from 2nd to 3rd then the gears clash badly (I mean really badly -- I'm cringing and my heart is breaking). Same if switching back into 3rd at high RPM.
But the worst is: I've accelerated at full throttle in 2nd driving up on a highway. I shifted into 3rd (a bit of clashing of gears), then tried to shift into 4th. I was able to shift out of 3rd but then unable to shift into any gear -- and the clutch pedal was "stuck" halfway in (or out, depending on one's view). I had to roll to a stop: more clutch pedal pushing, but no change in its position. Then I turned off the engine and restarted it -- and the clutch "released" and everything worked again.
If I drive the car at relatively low RPMs and doesn't attempt to power shift then the car (clutch/gearbox) works just fine (not even the clashing of gears when shifting into 3rd).
So what gives? Which part of the clutch fails at high RPM/high torque? I'm not well versed enough in the details of the clutch mechanism to be able to diagnose the problem.
Please help!
Old Dec 14, 2014 | 05:37 AM
johnnyb588's Avatar
Default Re: '04 V6 MT6 clutch/gearbox trouble
Good luck. My answer to your question has always been that Honda just made a crappy 3rd. I'm on my second transmission and both have problems with 3rd gear.
Btw, sorry, but I can't really offer any advice on the sticky pedal.
Old Dec 14, 2014 | 10:13 AM
VeeSykkz's Avatar
First off, the 6mt is known for bad 3rd gear synchros. Mine grinds on occasion bit nowhere near as bad as yours sounds.
Second. Sounds like you need a Clutch, flywheel and/or slave/master cylinder. Mine had a BROKEN flywheel when I bought it. If pedal is stuck in middle I would vote bad slave.
Old Dec 14, 2014 | 12:18 PM
neoteny's Avatar
Thanks.
Old Dec 29, 2014 | 01:31 PM
neoteny's Avatar
Well, they're going to replace the whole clutch assembly w/ a new & improved clutch design; same for the 3rd gear stuff, including the synchro(s). It is going to cost me an arm & a leg & my firstborn, but it'll be better than new.
Accord2k-Hybrid
Dec 20, 2006 05:26 PM
uuufffttaa
Jan 10, 2006 06:31 AM
lokodog
Dec 25, 2005 09:39 PM
japhonda
13
Jul 30, 2005 01:19 PM
JDMlyfestyle
21
Sep 24, 2004 02:08 PM
