94 civic ex compatible radiators
Old Dec 13, 2014 | 02:03 PM
waynesumner's Avatar
Default 94 civic ex compatible radiators
Hey guys ling time since last post, just curious what full size radiators are compatible with my ex. Currently i only have a small ine with the fan running and it rums good while cool but hets sluggish when warm, burning coolant and oil fairly quick. So looking to swap for a full size one with fan at the pick n pull. Which model and year hondas or acuras should i be looking for to do this?
Old Dec 13, 2014 | 02:58 PM
tony_2018's Avatar
Fish Twig
Default Re: 94 civic ex compatible radiators
There are no full size radiators that fit a civic, only half.
Old Dec 13, 2014 | 04:04 PM
dirty19's Avatar
Ridin Dirty in Cali
Integra rad will fit. but you'll have to move one mount.
You can move the lower drivers side mount out wider (requires tack weld drill out, and
reweld) once its in the correct position.
upper mounts can be found easily online or fabricated.
Dual core would be the best.
Old Dec 13, 2014 | 04:35 PM
Not in any position to fab any mounts atm. Will probably just try and find the other half sized one and hoses at pick n pull then. Does the other radiator have a fan on it or just one?
Old Dec 13, 2014 | 05:14 PM
grumblemarc's Avatar
The Grumpiest
What other radiator?
Old Dec 13, 2014 | 07:55 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I'm assuming the EX has AC so the other "radiator" is part of the AC system.
Old Dec 14, 2014 | 03:57 AM
HondaPartsHero's Avatar
Technical Hero
A new radiator isn't going to fix your issue. Your engine sounds like it's on the way out or you have some head gasket issues. How many times have you overheated it?
Old Dec 15, 2014 | 03:46 PM
I could be wrong but on the left theres the radiator and then the right theres some thing like the radiator, i guess it probably is part of ac system? But i think its connected through coolant lines. Only over heated once since iv had it and that was because a hose busted and coolant leaked out. Didnt drive. immediate pull over fix and refill. Could be head gasket because theres always been a runny oil coler on oil pan. Thought about tourqing down head bolts but afraid they may break or strip and ill be stuck with out car. Also read replacing head gasket isnt worth it because after fix theyll always blow faster but could just be BS.
Old Dec 15, 2014 | 04:14 PM
Technical Hero
Either way a new radiator won't help your issue unless your current radiator is bad already.
Old Dec 15, 2014 | 04:31 PM
The Grumpiest
Yes. You're wrong.
Old Dec 15, 2014 | 04:54 PM
tony_2018's Avatar
Fish Twig
Right, thats if he doesn't have the condensor in the way to put a full size radiator in, which wasn't explained.
Old Dec 15, 2014 | 05:01 PM
Uh yea, so what could be the issue if the car runs good (acceleration, gets up to speed easier) when the car is cool. But sluggish( bad acceleration, takes a while to get up to speed) when car is warm or ran for say an hour plus?
Ti3d in
Oct 8, 2005 02:59 PM
Raff
Apr 12, 2003 04:38 PM
