Anyone willing to cut a ctr/pct piston in half ???
Old Dec 13, 2014 | 05:17 AM
loiterin's Avatar
Default Anyone willing to cut a ctr/pct piston in half ???
Im wondering if anyone has an old ctr piston maybe from a blown engine that they are possibly willing to cut in half on a band saw etc ?
The reason I ask is I am considering milling some material off of a set of ctr slugs I have to flatten out the peak for better flame travel and more reasonable compression ratio. I am concerned about strength which brings me to my original question if anyone is willing to cut an old one in half so I can see what kind of material thickness im working with. Seeing as its the heaviest cast oem piston Honda makes I belive the dome to be solid cast material all the way through in which case I have no concerns. I only have 4 bnib ctr pistons so I cant cut one in half and I don't want to find out my thinking is wrong by starting to mill and find out I cant remove as much material as I think.
Old Dec 13, 2014 | 01:59 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Anyone willing to cut a ctr/pct piston in half ???
I would sell them and just use jdm type r pistons.
Old Dec 15, 2014 | 03:23 AM
loiterin's Avatar
Anyone In ? I know there has got to be lots of people with old ctr pistons kicking around....
Someone must be willing to cut one for some further education to the community ?
I will post pics throughout the whole milling process aswell as weight matching the pistons and finally cc the new modified domes
Old Dec 15, 2014 | 06:44 AM
93egSLEEPER's Avatar
Odds are not in your favor. Finding someone with a CTR piston, willing to cut it in half, and that has a band saw available to use could be very difficult.
What kind of motor are you building? There are probably shelf pistons available that will save you all the time/hassle.
Old Dec 16, 2014 | 07:10 PM
m4xwellmurd3r's Avatar
If you have the piston, why not test its density? Get someone to weigh it, in grams, then get a graduated cylinder to figure out the volume. Calculate density, look up the density of aluminum. I know the piston is an alloy, but if theres a big empy space of air it would show a greatly lower density than it should. If anything it should show up as denser than straight aluminum if it truly is solid throughout.
gsr96cx
Jun 20, 2008 04:06 PM
guedo148
Apr 15, 2007 09:08 PM
JJBRADLEY
May 8, 2006 07:44 AM
Eaglekper0046
Aug 3, 2005 07:18 PM
JsNA99si
Apr 16, 2004 12:10 PM
