B18b1 ALL motor build questions
Okay to start off I've done my research just want more input on this build
current build
1993 eg8(sedan)
1997 b18b1
Rebuilt b16 tranny(NON-LSD)
Completely stock
Stock ecu
Bar'd and ref'd
Micro polished cams(had it done for free from local shop included in with some hot tanking I had done)
Goals-I'm not looking to make anything crazy just something a little more fun to drive.
This is my daily so for the most part I'm keeping it stock/looking stock (I don't mind internal work like pistons and valvetrain because it's hidden obviously not building to pass smog)
Build-
P8R casting head
Port and polished
Milling
Hot tanked and bead blasted
Either stock cams micro polished/machine work and having the valve train micro polished or crower 403 cams w/matching valvetrain
Pistons I am unsure as to if typeR pistons are a good bang for your buck? I've seen them go for roughly 60-80$ in my town. Or if stocks will hold up fine
Porting the intake manifold to 70mm an polished or skunk2 carb legal
Porting the throttle body to 70mm an polished or skunk 2 carb legal
Dc 4-2-1 carb legal headers
Aem v2 carb legal intake
hondata s300 dyno tuned
Besides that leaving the block stock I only say pistons because I can replace them without dropping the block and can do it in give or take a couple hours.
Questions-
Is the Headwork worth the money?(no I'm not going Ls-Vtec this is a daily driven car and I have a whole other car that is built and not doing much to this car but make it more fun to drjve and looking stock as possible
Stock intakemani+throttle body with machine work or skunk2 carb legal?
would really love to here Imput of some veterans/people more knowledgable on the subject
Pics of motor-
current build
1993 eg8(sedan)
1997 b18b1
Completely stock
Stock ecu
Bar'd and ref'd
Build-
P8R casting head
Port and polished
Milling
Questions-
Pics of motor-
Get an LSD for your transmission. Run Crower 403 cams; don't bother changing the pistons; I'd also say don't even bother port and polishing the head.
Professional Products makes a much nicer TB than Skunk2; port match it to the manifold.
Def some good advice here. A good combo of bolt ons with something like crower 403s and a b16 Trans. Also get a tune even if just a street tune. Im there now just stock cams still it's quite fun around town
Okay so I decided **** keeping the Ls head most cops don't know the differene and I don't go around fast af, straight piped showing off like a little kid. So I picked up some 81mm ctr pyramid pistons and arp rod bolt. My question is it worth shot pinning(I believe that's how it's spelt) the rods?
As to my knowledge shot-peening/pinning is like putting small tiny dents in the rods that compresses them therefore strengthening them? I mean I plan on having it done since I already pulled the Ls pistons out and got arp rod bolts and plan on having everything balanced
Also yes I have e85 literally 5 mins from y house like roughly 2 miles from my house but this will be a daily driven build I want to kinda stay away from tuning on e85 cause it's more of a hassle whenever I travel or go out of town. But I do know it's a lot better and can pull more power out of e85
But these pistons came out if a b18b1 LS vtec I assumed he bored it over? Re sleeved it. Iran I can ask him how he made them work but he did.
Back on subject I've read all over this site of people using b16 pistons pr3's are they good for LsVtec? I would assume it's around a 10.1 CR with my b16 head?
I like ITR pistons on the 89mm crank/rod combo. Excellent CR for street and VERY tuneable with TONS of options for cams. Check out slowsleeper on here. He has a LSV w/ ITR pistons making 240whp...and it's a pretty simple setup.
I'm in no way trying to argue or proclaim in right your wrong in no way whatsoever and seriously looking for help or I would have never of made the post
sleeper is right, itr pistons are a solid choice. unless you are doing something crazy with huge cams, 9000+rpm or e85 or other fuel above 93 octane you dont have to go nuts with compression and somewhere around 11-11.5:1 gets the job done
i ran that setup of pr3's in an ls block with a b16 head last year. i used itr cams. the compression is borderline too high, right about 12:1 depending on your headgasket and any milling/decking done. with a big cam i think you can do it but its right on the edge of diminishing returns if you ask me. my setup was only running 27 degrees total i believe on 93 pump at wot in vtec or it would detonate. it was also only running low to mid 20's for timing up through 12-13" below 3000 rpm or it would detonate. id honestly rather have a bit lower compression and add timing. sleeper is right, itr pistons are a solid choice. unless you are doing something crazy with huge cams, 9000+rpm or e85 or other fuel above 93 octane you dont have to go nuts with compression and somewhere around 11-11.5:1 gets the job done
I am pretty sure slowsleepers build had some portwork amd went upwards of 9000 rpm but it is still a pretty straigjt forward setup. Its really all about parts that work together
https://honda-tech.com/all-motor-nat...-dyno-3092090/
Here is the build. He's an awesome builder so results like this ARE NOT common.
But if you wanna stay na, definitely go lsv.
I have a build b18a1 with a sweet ls head (uninstalled needs a rebuild) but if I didnt get the head so cheap I wouldve gone vtec
What are your guys opinion on toad racing vtec killer cams? I have a buddy that runs them on his LS-V and he loves them or never heard bads about them but I would love some imput(yes I'm going to do research but more what I'm looking for is why I should use so and so with them and benefits and why I shouldn't because I can't use or do with them.)
After a night if looking into them I understand more why the big 2-lobe setup wouldn't be very optimal for daily driven. I mean I still HIGHLY considering just boosting my Ls cause it's easy to make a good fun amount of power but at the same time I want to go Ls-V cause really all I would have to do to go from all motor to boost is turbo cams and turbo pistons to make good power. And obviously fuel pump and injectors ect for turbo
Thats how I built my ls. Forged piston/rods, right around 10.8:1 ported head, jge303 cams, valvetrain, etc. The head needs a rebuild but for a stock head ls the thing friggin scoots na. Shooting for 400hp/250tq@8500 rpm. The ported head should be able to do it, my engine can live up there. If I get anywhere close to that number ill be happy. Right now its making over 150whp and 140wtq on the stock head. Ported head should make north of 180hp im hoping.
For
Crower 403 cams
1st gen skunk2 intake mani +throttle body ported to 68mm
Chipped p75 basemapped for stock Ls with the same cams until I get it tuned
And RC 330 injectors I believe
And he gave me 100$ ontop.
I already hae acl rod/main bearings, arp rod bolts, arp head bolts and shot preened Ls rods. What pistons can I use that will make good power N/A but when I want to boost it I can also boost them?
ITR.#1446
Jun 7, 2005 12:47 PM
