Car is 99 ex coupe. Picked it up not too long ago, just found these plugs dangling.
Where do they go?
Also, there is one brown plug above fuse box, with what looks to be a wire that had been ripped out. What is that brown plug?
You can see the two plugs hanging, and the brown plug with no wire.
Better view of two dangling plugs. Single wire plug is blue w red stripe, two wire plug is blue and black wires.
Now to the right, by stereo/gas pedal, there is this wire hanging. Two wire plug, white and red wires.
The 1P Brn connector (C406) with the Blu/Red wire is for fog lights.
3P Gry connector (C450) has Blu and Blk wires. It's for the valet switch of the security system, which I see in your picture.
The Brn plug without a wire in the dash fuse box is option slot 1 (C926) and the one to the right (blue insulated plug insert) is option slot 2 (C927).
LEFT SIDE:
Brown plug dangling: got it.
Brown plug w no wire: got it.
Gray plug dangling: valet switch for security system? So what do I do with it? Does it plug into something, or just stay unplugged for when some external switch uses it? I'm not the original owner, so I only have one key and now key fob.
RIGHT SIDE:
Here is a better image of it, and I undid the plastic ziptie that was holding it all scrunched up.
