90 civic i acting weird
Old Nov 2, 2002 | 10:43 AM
cr-x si's Avatar
Default 90 civic i acting weird
Ok my friend just bough a 90 civic w/ a z6 swap last week and it is alread f*cked up. When you drive it, it is like missing. It dose it all the time. The car is giving a code 9 on the ecu and the check engine light came on. I am trying to help him cause he don't know **** about hondas , and it is his first car. So what do you guys think the problom is? Please help you can
holla
Old Nov 2, 2002 | 05:11 PM
Perfectionist's Avatar
Default Re: 90 civic i acting weird (cr-x si)
Code 9 is the cylinder position sensor. It's in the distributor. That would explain the miss.
Old Nov 3, 2002 | 08:45 AM
cr-x si's Avatar
Default Re: 90 civic i acting weird (Perfectionist)
do you know how i could fix it??????
Old Nov 3, 2002 | 09:03 AM
4drEF's Avatar
Keyboard Humorist
Try a new distributor! Make sure that the distributor matches the ECU. If the previous owner did an OBD0 to OBD1 conversion then it should be running a P28 with the OBD1 distriutor. If it's running with the stock OBD0 ECU (PM6) and a vtec controller or RPM switch to activate the vtec, then it should have a MODIFIED OBD0 distributror on it. Moddified? yeah... take a look at it... make sure it's modded. The 3 "ears" on the 88-91 Si distributor do NOT line up correctly to the Z6 head. 2 of the "ears" must be radically notched out to allow the bolts to fit in.
You can usually find a used OBD0 distibutor for about $50-$100 depending on who you get it from. OBD1's normally run $75~$150 used.
If you look into it, you can find places that rebuild distributors for about $75.
Old Nov 3, 2002 | 10:43 AM
cr-x si's Avatar
Default Re: 90 civic i acting weird (4drEF)
That helps a lot. the car dose have a pm6 ecu and the distributer bolts don't line up correctly. And it has a vtec controller. So he has to get a obd1 distributer and a p28 ecu right? What cars do those parts come from?
Could he just disconnect the vtec controller to fix the problom untill he gets the right parts?
Thanks
[Modified by cr-x si, 7:55 PM 11/3/2002]
JuneBugDrfter
Aug 8, 2013 12:39 PM
88EDHatch
Dec 3, 2010 10:02 AM
efdxjdm
13
Sep 12, 2009 04:23 PM
BuGz32crx32
Sep 23, 2008 10:43 PM
Maddox
10
Apr 11, 2004 11:24 AM
