11.1--11.5 compression in a b16a2? anyone? and how?
i'm looking to make a good 11.1-11.5 CR in my 2000 civic si to match up with the Toda b Cams.
anyone doing this. What pistons are you using and with what headgasket?
Milling my head is out of the question so any other setup answers would be appreciated.
Thanks
i'm asking because i orderd some JE pistons..and i'm not sure if i received the right ones. i received GSR pistons 12.5 CR...will they make what i need in my B16a2...an 11.1-11.5 cr.
[Modified by texasSI, 1:42 PM 11/2/2002]
Thanks
CTR pistons and a 2 layer headgasket should put you about where you want to be. Check out www.c-speedracing.com for a compression ratio calculator.
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
COREY ITR#625
Nov 21, 2001 07:55 AM
