4500 rev limiter on non vtec 94 accord
Old Dec 9, 2014 | 08:28 AM
Elmorro_jo3's Avatar
Default 4500 rev limiter on non vtec 94 accord
My car is only reving up to 4500 Rpms. I need help on how to fix the problem. Cleaned the IACV and replaced the hose that connects under the throttle body and IACV. Also replaced thermostat and gasket and flushed coolant. Starts right up no problem. Just losses a lot of power running and rev limits at 4500 rpm. Thank you in advance!!!
Old Dec 9, 2014 | 08:58 AM
holmesnmanny's Avatar
Check for stored codes .. number one cause is bad distributor sensors
Old Dec 9, 2014 | 10:43 AM
Fitz Williams's Avatar
10 Year Member
Default Re: 4500 rev limiter on non vtec 94 accord
Make sure it's really stopping at 4500 and not that your tach is slow. Mine is very slow. Compare your speed at 3000 to what your car should actually be doing.
Old Dec 9, 2014 | 11:52 AM
it barely makes it up my drive way
Old Dec 9, 2014 | 12:49 PM
professorman's Avatar
Have you done a compression check recently?
Old Dec 9, 2014 | 03:45 PM
Nope not yet but I'm going to check the map sensor
KidAccord
Mar 21, 2013 05:51 PM
Koietsu
Feb 26, 2011 05:35 AM
mony725
10
Apr 5, 2009 01:19 PM
Homesickelian
Dec 20, 2006 06:06 AM
Woogie Ctr
Apr 11, 2006 03:08 PM
