Rear Fog light install on USDM hatch bumper
Old Dec 8, 2014 | 07:50 PM
cjwang2's Avatar
Default Rear Fog light install on USDM hatch bumper
Hi All,
I've been wanting to install a rear fog light on my USDM 1990 Civic Hatch. I was doing some research online and I saw that you could install rear fog lights on a USDM sedan rear bumper without making any cuts to the bumper support:
Rear Fog Light Questions....
EFCivicSedan.com :: Install Rear Fogs
I went to the junkyard the other day and took off a sedan bumper and saw that there was basically no room between the bumper and the bumper support. Also, the bumper support only had 2 small holes for the styrofoam filler, definitely not enough room for the rear fog light to pass through. I pulled off a hatch bumper and it was pretty much the same as the sedan. Also, there were no marks or tabs on the inside cover of the bumpers. Has anyone done this? If so, how did you get the fog to fit with the bumper support still on? If anyone has pics, that would be great.
Thanks!
Old Dec 9, 2014 | 12:11 PM
cjwang2's Avatar
Default Re: Rear Fog light install on USDM hatch bumper
Anyone?
Old Feb 2, 2015 | 06:43 AM
cjwang2's Avatar
Finally got around to installing the rear foglight. I had to cut a pretty big hole in the bumper support and I also found out that the OEM foglight bracket does not fit on the USDM bumper cover. I had to fabricate some brackets, using some metal strips from Home Depot. All in all it looks good.
Old Feb 2, 2015 | 10:35 PM
Ef4doorwagon's Avatar
Looks good. I did something like that when I put prelude fogs on my EF, but I cut one of the squares too big and it looked ugly lol
Old Feb 3, 2015 | 06:12 AM
cjwang2's Avatar
Thanks! I did the same to my front bumper too, for my Prelude front lights. I kinda messed up the cuts on my front bumper, but the lights are big and you can't really tell...
Old Feb 3, 2015 | 01:37 PM
ef_blanco's Avatar
I need to do that to my crx bumper too.
Old Feb 4, 2015 | 03:19 PM
speed1's Avatar
Nice. I guess I have to go back to junkyard and grab those babies.
Old Feb 4, 2015 | 10:34 PM
Hey cj how do your brackets for the front look like? When I mocked mine up, I used the stock prelude brackets that attach to the top of the fog light, then I used some L brackets and bolted them to the car, near where the horn goes.
Old Feb 5, 2015 | 06:17 AM
cjwang2's Avatar
I used the same thin pieces of metal that I used for the rear fog in the pics above. They are easy to bend and hold their shape well. Plus, you can fit bolts in the holes, if you just widen them a tad. I have the "brackets" bolted onto the bumper support and they have been on the car with no problems for 2 years now. I believe the brackets are around $0.87 at Home Depot. 1 or 2 should be enough.
Old Feb 5, 2015 | 09:46 AM
James89DX's Avatar
I guess I'm not JDM enough to know the answer, but why is there only one light?
Old Feb 5, 2015 | 02:22 PM
@james
I think its just what looks better to you. I've seen the jdm rear bumpers with 2 fogs, and a lot of Hondas with just one, usually on the left side.
To me its kind of like the eg duckbills that go upwards instead of outwards, no performance gain just cosmetic points.
But fogs on efs look sweet, and if you own an EF then you know to mount them takes creativity.
89civicstd
Jun 4, 2015 12:08 PM
BigDare23
Jun 1, 2010 11:27 AM
BigDare23
Southeast (Sales)
JDM95lude
Jul 17, 2006 08:06 AM
4DRmafia
Feb 24, 2006 09:09 AM
