Temp gauge issue
Old Dec 8, 2014 | 11:06 AM
therhett17's Avatar
Default Temp gauge issue
My temp gauge on my 97 Accord 4cyl has never worked properly since I've owned it, (it never moves beyond the blue/first mark when driving) but I've recently found it does respond when the engine overheats. I had a coolant leak while driving and I knew something was wrong because the needle went to the middle mark on the gauge (where it should be normally). Fixed that and it's stuck down in the blue again like usual. Any thoughts? Thanks!
Old Dec 8, 2014 | 11:10 AM
cfauvel's Avatar
Default Re: Temp gauge issue
a simple temp sender change is in order.
Old Dec 8, 2014 | 11:15 AM
therhett17's Avatar
My uncle is a mechanic and he replaced the sending unit. That's all we've tried so far (and it didn't fix it).
Old Dec 8, 2014 | 11:52 AM
holmesnmanny's Avatar
Sounds like the thermostat is stuck open. To test, with the car completely cold, start her up and just idle her and see if the lower radiator hose starts getting warm almost immediately, or within a couple minutes. If it gets warm almost immediately then get a new thermostat from Honda. Do not get an aftermarket. The Honda ones have built in failsafes. Make sure to bleed the system properly when installing it.
A normal car will take about ten minutes or so for the lower radiator hose to start getting warm.
Old Dec 8, 2014 | 04:24 PM
therhett17's Avatar
I thought I had ruled out the thermostat because my heater works good and doesn't take that long to warm up, but I'll try that and see! Thanks
Old Dec 9, 2014 | 06:48 AM
therhett17's Avatar
Felt the hose this morning, to no avail. Any other ideas?
Old Dec 9, 2014 | 08:57 AM
Temp sensor or cluster
Old Dec 9, 2014 | 10:48 AM
professorman's Avatar
Check this tread: https://honda-tech.com/honda-accord-...andom-3190203/
I had the same issue and I went through numerous diagnostic procedures outlined in the tread. Mine ended up being that the soldering came loose on the circuit board.
djfob
Feb 16, 2018 05:27 PM
lilo_goki
Mar 27, 2011 09:38 AM
Frederick_Est87
Jul 25, 2009 10:05 AM
Andrew Sutherland
Jun 29, 2008 08:55 AM
B00STED Si
Jun 16, 2005 08:26 AM
