Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 CR-V hard starting when warm
Old Dec 8, 2014 | 10:15 AM
Twin_Cam's Avatar
Default 2005 CR-V hard starting when warm
I know what you're going to say and yes, I have used the search and couldn't find anything conclusive, although I do have some ideas.
2005 CR-V EX, auto, 101K miles. Sputters and idles very low for a few seconds after certain warm start situations. When this occurs, will occasionally dump the radio memory, resetting all of my nerdy audiophile custom EQ settings (oh, the humanity!).
From my research, I should check the PGM-FI relay (still trying to figure out where that is exactly) and the engine coolant temp sensor, which I believe is located on the passenger side of the cylinder head. I'm leaning toward the relay, because of the radio memory thing. So, how do I check this, and where is it if I need to replace it? Thanks.
renots128
Honda Civic (2001 - 2005)
Jul 30, 2015 04:30 PM
JDC2TypeR
Feb 4, 2008 10:53 AM
1BADEGDC2
Sep 9, 2007 07:49 AM
90_civic_Si
Dec 7, 2006 11:56 AM
904d
Feb 15, 2005 08:34 AM
