Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car Suspension?
Old Dec 8, 2014 | 09:12 AM
alison1989's Avatar
Default Car Suspension?
I drove over a large pot hole this morning which caused my front passenger Tyre to burst. It has now been replaced with my spare Tyre, however when I drive, my steering heavy. I have a feeling I might have also caused damaged to my suspension? Or could it be because I'm driving with a spare Tyre? Or maybe to do with the wheel alignment? (My friend did struggle to remove the tyre)
Please can someone advise?
Thank you.
Last edited by alison1989; Dec 8, 2014 at 09:57 AM. Reason: Added more to the thread
Old Dec 8, 2014 | 08:29 PM
Djratrap's Avatar
Default Re: Car Suspension?
Get your old wheel/tire fixed asap. Driving with a spare is all around bad for the car and dangerous. The traction will not be there if you make an evasive more or hit a little bit of rain.
Old Dec 9, 2014 | 06:18 AM
lowlife9's Avatar
how can we even begin to diagnose anything ??? have it looked at or at least post pictures.
Old Dec 9, 2014 | 09:58 PM
toyomatt84's Avatar
Sanji
What kind of car is this?
Old Dec 12, 2014 | 07:16 AM
alpine87's Avatar
If you have some spare time (you'll only need like 15 minutes) take the tire off and then put it back on immediately. This time you want to make sure you're doing it properly. Bolts started by hand to avoid cross-threading, tighten on one-by-one using a "star pattern" (start one bolt, then do the opposite one across), and then if you have a tool to do so properly torque each bolt (80 ft lbs).
The tire is also probably smaller in both height and width than your other times, causing uneven traction between your two front wheels. Indeed the best practice is to get that wheel replaced ASAP.
If you're still concerned, have a professional look it over to be on the safe side.
JDM3STAGEVTEC
Apr 27, 2009 05:25 PM
User 12720
Suspension & Brakes
Dec 11, 2008 10:55 AM
Bantam
Mar 24, 2003 01:27 PM
SpiritUnreal
Sep 21, 2002 09:02 PM
ncitrdude
May 15, 2002 12:37 PM
