Can't pry off the Breather Box
Hi
How are you guyz? I am new in this forum. My 7th gen civic 2002 has D16W9 engine, which has Plastic PCV valve with grommet. During removal it was broken and fell down in PCV breather box. Please see picture. I am successful in removing all the 6 bolts including the top one, but the breather box/chamber remained fixed. Please help me what should I do?
here is the link of Picture:
http://www.civicforums.com/forums/at...2&d=1210298788
Mine had plastic PCV valve instead of the metallic.
Thanks in Advance
Regards
Thanks in Advance
Regards
its held on with Hondabond sealer ,so the sealer needs to be cut/broken if you have a very thin putty knife/razor blade you can insert into the area where sealer is and cut it, usually once it is broken loose in one area it will start to pry off the rest of way around
igorka_91
Welding / Fabrication
91
Apr 16, 2013 09:31 PM
Historyg
Oct 13, 2008 02:27 PM
