89 Civic SI - Right Transmission mount bracket, Where do I get one?
When looking at the right trans mount yesterday I noticed the nut that bolts to the trans mounting bracket (the bracket that bolts directly to the transmission) was missing and this caused the other bolt to break the welded nut on the other side of the trans bracket.
I showed the bracket to a weld guy and he seemed to think that even if the nut was welded back on it would just break again because the metal bracket is too thin.
Temporalery I used a heavy washer and bent it to fit under where the broken weld is and then used a nut to crank it tight (kinda of a hack but it worked).
I have not found anywhere online or local Honda dealers that can get that bracket? Anybody know where I can find one?
Thanks
Thanks
Honda, plenty of websites where this mount should be available.
Edit: just searched and looks discontinued. Print the page below and call the local dealers to see if any are available. Otherwise junkyard or fix the original
http://www.afhparts.com/honda/civic-...g-mt&position=
1990crxsir
May 29, 2006 04:43 PM
