Velocity stack
Old Dec 6, 2014 | 05:28 PM
Codyv17's Avatar
Default Velocity stack
So how many guys here are fans of and believe in velocity stacks on there all motor builds? My tuner is a huge fan and highly reccomended me. I apologize in advance if i am posting in the wrong section considering i am new here.
Old Dec 6, 2014 | 09:22 PM
ChrisCoupe1's Avatar
Default Re: Velocity stack
They can help make power when properly sized, designed, and tuned for your build sure but you run the risk of foreign matter along with bugs, dust, dirt and whatever else getting ingested in to it. The amount of gain you get might not be worth the risk depending on what measurable gain you can get. If your pushing for every conceivable advantage then go for it.
Old Dec 6, 2014 | 10:08 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I have SU carbs, so they are a necessity, but I have air cleaners over them, the idea is to smooth the airflow into the carb throat
Old Dec 6, 2014 | 10:51 PM
TracerAcer2.2L's Avatar
Anti-GDD White Knight Simp
There are plenty of intakes that utilize velocity stacks with a filter. Don't worry about sucking up foreign matter. Even if you get a stack with no filter, a sock filter can easily be had.
If you want to gain 2 hp for 30-80 bucks, go for it. Unless you're talking ITBs or a Vision intake, that's a whole other story
Old Dec 7, 2014 | 08:19 AM
PSI GUY's Avatar
Mine actually made more power on the dyno with the filter on the stack, but, at higher mph you would gain without the filter if it is forward facing out of the vehicle.
Old Dec 7, 2014 | 04:16 PM
Too bad only K series can do that^^^ although I may have an idea for H series...
Old Dec 14, 2014 | 04:22 AM
GhostAccord's Avatar
No need to worry about any foreign matter. Velocity stack and K&N filter.... works great!
It raised the MID to High PRM power range and gained MPG while cruising. Glad I made the switch!
skyfan
Acura TL, RL & ZDX
10
Mar 21, 2008 03:49 PM
mackoy20
Jun 25, 2007 10:59 PM
stevescivic
Jan 26, 2007 02:43 PM
ThinHoanG
Jun 12, 2005 04:43 AM
Nihilation
Aug 13, 2004 09:48 AM
