2003 Civic 1.7 fuel pressure
I'm looking for a Fuel Pressure tester for a 2003 Civic with a 1.7 V tech. One I can buy that won't break the bank. The one from Honda is over 200 dollars. Or if there are adapters available for the quick connect fittings on the fuel rail that I can adapt to my current gauge, that would work as well. Thanks for any info anyone might have!
Thanks but I have that connector, but it is not used on a 2003 Civic 1.7 motor.......the hook up for this model is where the fuel pressure line goes to the fuel rail and is a quick disconnect type fitting. The banjo bolt fitting is for a different model and goes to the top of the fuel filter on the firewall. On a 2003 civic the only fuel filter is in the tank and is part of the pump assy. Honda sells an attachment kit for this model but it is 218.00.
padge
Jan 8, 2003 08:18 PM
