Engine Harness - what is this connector for?
Old Dec 4, 2014 | 09:54 AM
SebMDtuning's Avatar
Default Engine Harness - what is this connector for?
Hey guys, I'm checking for all the information required to build my own harness for my race car and I was wondering what this connection was for?
Car: Civic 97 Coupe si
Used for: Drag racing only
Base Engine: B18C
Panel switch: ARC8000
Computer: Hondata S300 v2
Other: 16V battery
Goal: get rid of my OEM wiring and fuse box and make my own harness!
I will validate by tearing apart my OEM harness later this week, but I wanted to clarify what this really was for since I couldn't find what the exact purpose of that junction/loop connector on the web.
Thanks for any input!
Seb
Last edited by SebMDtuning; Mar 29, 2015 at 08:41 AM. Reason: Added more car and engine details
Old Dec 4, 2014 | 09:57 AM
Former User's Avatar
Default re: Engine Harness - what is this connector for?
More information is needed. How can anybody help you if you don't post what car/engine the harness is for?
Old Dec 4, 2014 | 10:04 AM
DieMaster's Avatar
Needs to be About 20% Cooler
it's a power splitter. i think it's used to split ig1 power to the 4 injectors. that or a blank unused plug.
Old Dec 4, 2014 | 10:11 AM
Indeed, I'm building a harness for my B18C ODB2 and there's two closed connectors like this one on my actual harness. Hope this clarify more...
Seb
Old Dec 4, 2014 | 10:13 AM
Your picture is grayscale. What wire colors are in the OEM junction connectors?
Old Dec 4, 2014 | 10:22 AM
Thanks for the quick reply, I will post actual pictures tonight and include the pinout from ECU as well if I can get to this point.
Seb
Old Dec 4, 2014 | 10:59 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Depending on year and model, if it is an OEM 14-P blue junction connector with Blk/Yel and Grn/Blk wires, it is used to split/distribute power (via the Blk/Yel wire) and ground (via the Grn/Blk wire).
Terminals grouped together are connected by the same bus bar.
Blk/Yel wires distribute power to some or all of the following:
• Evap control canister vent shut valve
• Evap purge control solenoid valve
• VSS
• Primary HO2S
• Secondary HO2S
• PCM
• Alternator
Grn/Blk wires distribute PCM sensor ground signals to some or all of the following:
• Fuel Tank Pressure sensor and Fuel Tank Temperature sensor
• TP sensor
• ECT sensor
• IAT sensor
• Primary HO2S
• EGR valve lift sensor
Depending on year and model, if it is an OEM 14-P gray junction connector with Yel/Blk or Yel/Red wire and Blk wires, it is used to split/distribute power (via Yel/Blk or Yel/Red wires) and ground (via Blk wires).
Yel/Blk or Yel/Red wires distribute power to the following:
• Individual fuel injectors
• IAC valve
Blk wires distribute ground from G101 to some or all the following:
• PGM-FI Main Relay
• VTEC Pressure
• Power Steering Pressure Switch
• Fuel Pressure Regulator Shut-Off Solenoid Valve
• Engine Coolant Temperature Switch
• VSS
• PCM
Old Dec 4, 2014 | 11:18 AM
Thanks a lot tech8 really clarifies a lot of things
Seb
Old Dec 5, 2014 | 01:14 AM
Here's the actual picture coming from my old engine harness. There's also a brown rectangular connector that seems to be doing the same thing closer to the ECU connectors where importants wire and some grounds are going to...
I just need to figure this out before starting to build my own with was is necessary to run my racecar.
Thanks!
Seb
Old Dec 5, 2014 | 02:40 AM
HondaPartsHero's Avatar
Technical Hero
Download the manual or google image search the wiring harness diagram for your year. It will tell you where each wire goes. Those are commonly referred to as "dead end plugs".
Old Dec 5, 2014 | 04:39 AM
What car/year did the harness come from?
Old Mar 29, 2015 | 07:04 AM
Thanks man!
Do you know where the power and ground are coming from? Ar both sent by the ECU ? Hondata S300 in my case...
I see PG1/PG2 (Ground) and LG1/LG2 (Logical Ground) but I can't seems to find a pin-out that sends 12v except for TPS and MAP that is corrected to 5v.
Thanks in advance!
Seb
• VSS
• Primary HO2S
• Secondary HO2S
• PCM
• Alternator
• TP sensor
• ECT sensor
• IAT sensor
• Primary HO2S
• IAC valve
• PGM-FI Main Relay
• VTEC Pressure
• VSS
• PCM
vtecjunkiie631
Jan 2, 2024 04:58 PM
DerekHollister
Apr 12, 2015 10:25 AM
zdiddy22
Oct 14, 2013 08:51 AM
crxhybrid1320
May 26, 2010 02:28 PM
mec. pedri
Nov 10, 2006 02:26 PM
