Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Honda Civic Driver Door Lock Not Turning w/ Key
Old Dec 3, 2014 | 07:50 AM
Civiccity03's Avatar
Default 2004 Honda Civic Driver Door Lock Not Turning w/ Key
Hi guys, I got a 2004 Honda Civic thats driver door lock won't turn with the key. When you put the key in the door to lock it, it will not turn. It will not lock or unlock at all. Does anyone know how I can fix this issue?
Currently I have to go to the passenger side and unlock the car like that to get in. Any help would be appreciated, thank you!
Old Dec 5, 2014 | 08:30 AM
Humphrizzle's Avatar
Default Re: 2004 Honda Civic Driver Door Lock Not Turning w/ Key
there's most likely a bunch of gunk in the door latch linkage. if you take the door off, clean as needed and use shin etsu grease on the components, you should be fine.
Old Dec 7, 2014 | 01:00 PM
I sprayed graphite spray and WD-40 in the lock, but still nothing. Wouldn't that have helped it out if it was gunked up?
Old Dec 8, 2014 | 08:04 AM
rockycat's Avatar
The linkage is the rod and levers that go to the inside lock. Slim jiming is a usual cause of bent linkage. Next is a tumbler mismatch with the key.
Old Dec 16, 2014 | 11:08 AM
Guys, is there anyway I can use the passenger side lock on the driver side?
ayau
Feb 10, 2013 01:45 AM
awwsnap
Feb 3, 2010 10:47 PM
Fdisc
May 18, 2008 05:37 PM
