Best hole saws for Stainless steel?
Old Dec 2, 2014 | 08:14 PM
ShaudFAB's Avatar
Default Best hole saws for Stainless steel?
Hello all,
I am have been going through so many hole saws. Can anyone recommend me to some good quality hole saws for sch 40 stainless steel?
Old Dec 2, 2014 | 08:28 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Best hole saws for Stainless steel?
are you making the same parts over and over? have you considered having the holes laser cut? you are definitely going to need at the minimum a hole saw with cobalt teeth or carbide . Are you using cutting fluid? you can't cut stainless dry, and you need the slowest possible speed you can get. The stuff is going to be hard on holesaws no matter what you do, but the idea is to get as much life out of them as you can.
Old Dec 3, 2014 | 03:23 AM
that-guy's Avatar
if he's doing something repetitive, he's best off to have them cut on a mill using a jig
Old Dec 3, 2014 | 06:22 AM
HellaFab's Avatar
annular cutter with flood coolant.
Old Dec 3, 2014 | 07:02 AM
that-guy's Avatar
basically what I was getting at
Old Dec 3, 2014 | 11:04 AM
weiRtech's Avatar
OG Fabricator
a plasma cutter will save you tooling costs.
Old Dec 3, 2014 | 11:27 AM
HellaFab's Avatar
You would plasma stainless? With compressed air?
Old Dec 3, 2014 | 12:34 PM
kingofbattle909's Avatar
Milwaukee hole saw set ftw.
Old Dec 3, 2014 | 01:45 PM
we've had the best luck just having them laser cut, you end up with a very small burr that needs to be cleaned up, but it's easy, we have tried hole saws, cutters in the mill etc,
Old Dec 3, 2014 | 01:46 PM
depends on the type of stainless, they are all really tough on any kind of tooling though
Old Dec 4, 2014 | 06:51 AM
weiRtech's Avatar
OG Fabricator
yes, all the time. for odd shaped holes it is very time effective. as long as you put a smaller diameter half pipe inside to catch the slag and do a bit of clean up after with a die grinder, it turns out fine.
Old Dec 4, 2014 | 10:08 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
MMMMmmm work hardening...
Old Dec 4, 2014 | 10:16 AM
ShaudFAB's Avatar
Thanks for all the input. I picked up some bosch bimetal hole saws and they are working great so far on stainless sch 10 304l.
Old Dec 5, 2014 | 05:33 AM
CODE4's Avatar
Clean shop air will work fine, but argon will make for an even cleaner cut. Grab a high pressure flow meter (~80 psi I believe) and modern plasma cutters will not fault from low input pressure. Little to no sugar to clean up.
Of course some will argue that it is a waste of argon blah blah but how much is your time worth? In a production environment it costs less.
G19doug
Welding / Fabrication
Dec 29, 2014 07:11 PM
trancedroller
Apr 17, 2010 02:42 AM
PTPbracket
Nov 18, 2008 09:12 AM
Fred Allen Burge
May 2, 2006 11:04 PM
Justin Olson
31
Oct 14, 2005 01:27 PM
