2001 hons CIVIC LX - CRANKS BUT WONT START AGAIN1
Old Dec 2, 2014 | 04:30 AM
hdrk-rick's Avatar
Default 2001 hons CIVIC LX - CRANKS BUT WONT START AGAIN1
This morning makes 4 times. I come out of work after an 8 - 10 hour shift and i try to start the civic but it only cranks and will not start. It sometimes seems like it is going to start but it does not. The prior 3 times I have had the civic towed home and it starts and runs great. The third time this happen we checked for 5 volts at the CPS and it started and ran for a week. The car does need coolant added often. Have not taken the time to determine if it is a head gasket or not. Battery light stays after the alternator was taken off and re installed due to a broken alternator bolt. Even stays on after the installation of a used alternator. This is the 4th time it has happen. What could make it crank and crank with no start. Then a tow home and it starts.
Any help would be very much appreciated. Thanks
Old Dec 2, 2014 | 07:39 AM
2tonenintendo's Avatar
Default Re: 2001 hons CIVIC LX - CRANKS BUT WONT START AGAIN1
Sounds like possibly your main relay (fuel relay) is crapping out on you. I had this happen on two different Hondas.
firefox15
Honda Civic (2001 - 2005)
May 21, 2014 04:30 PM
mr.s_rod_89ef
Apr 20, 2013 05:00 PM
osn grind
12
Aug 15, 2011 08:47 AM
600_Double_R
Jun 29, 2011 11:01 AM
