cam holder dowel pins...?
Old Dec 1, 2014 | 09:46 PM
vroomvroomjdm24's Avatar
Default can holder dowel pins...?
Do I need to replace these pins?
Old Dec 1, 2014 | 10:56 PM
Runnerdown's Avatar
Default Re: cam holder dowel pins...?
In your case yes, that one got fcked up. Sloppy assembly got the best of that one.
Old Dec 1, 2014 | 11:28 PM
I just got these off eBay smh . -.-
Old Dec 2, 2014 | 02:29 AM
Runnerdown's Avatar
You also got 1st gen cast B16a pieces scratched all to hell. Those oil holes where they meet the cap rely on a machined smooth surface with no seal. Scratches or gauges could result in leaks and less oil coming of the holes onto the cam lobes. Inspect them carefully.
Old Dec 2, 2014 | 05:49 AM
Should I get the other style cam holders ??
Old Dec 2, 2014 | 08:55 AM
Runnerdown's Avatar
I'm not aware of a functional difference between those and the newer versions.
Old Dec 2, 2014 | 03:41 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: can holder dowel pins...?
I believe you can use a vise grip and pull them out and tap a new one in. I looks like the threads from the bolt dug into the dowel, you can see the threads made inside. Might want to look in the threaded hole on the head to see if its damaged. Looks like it wasn't flush when the bolts got torqued down.
mattcivic
Jul 2, 2012 08:51 AM
B18C-YA!
Jun 1, 2006 09:17 PM
Austin
Jul 26, 2005 08:14 PM
civiclxb16a
Jul 21, 2005 09:13 PM
UNDER PRESSURE
Nov 18, 2003 10:19 PM
