B18C1 Oil Pan Sealant?
Old Dec 1, 2014 | 05:10 PM
mdb4879's Avatar
Default B18C1 Oil Pan Sealant?
I'm about to reseal my oil pan on my 1995 Integra GSR and have a small question. I've done oil pans on other motors where a gasket isn't required and you can lay down a bead of RTV on the mating surface instead. Is it ok to do this on a B-series in place of using a gasket? I haven't gotten to cleaning the mating surfaces yet, so I haven't checked to see if there are recesses in the oil pan for the bead like in other pans I've done before. Although I'm not so sure that is much of a determining factor for if this is a viable procedure. Thanks in advance for your input.
Old Dec 1, 2014 | 06:54 PM
B(eighteen)C's Avatar
Default Re: B18C1 Oil Pan Sealant?
youre better off with just buying anoyher gasket. cleaning the rtv off the oil pan might w easy but youll have a hard time going around the studs on the block and getting everything of completely
Old Dec 1, 2014 | 07:08 PM
Tyler Dirden's Avatar
I am Jack's...
You must use a gasket. The oil pan has anti crush bumps that keep a gasket from squishing out.
Put a FelPro gasket on. It is a blue silicon rubber permadry type that is the best gasket I have ever used in these motors. no sealer required except where the oil pump meets the block put a little dap.
Old Dec 2, 2014 | 06:12 AM
romerosi's Avatar
I would only use Honda gasket and Hondabond. ive used other gaskets and sealers and they all leak after a while
Old Dec 2, 2014 | 10:57 AM
holmesnmanny's Avatar
Felpro
Old Dec 2, 2014 | 11:00 AM
mdb4879's Avatar
Gasket it is then, thanks for the help. I see what you're talking about with the dimples/stops on the oil pan. A bead of sealant wouldn't have worked anyways. I picked up a Felpro gasket today and will use it once I get my rod bearings in and installed.
bpoweredeg6
Jun 9, 2016 01:54 PM
Yuta
Nov 6, 2015 06:06 AM
TypeRod
Sep 17, 2009 06:32 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
S13 slide
Aug 22, 2002 08:37 AM
