steering wheel ignition lock bolts?
Old Dec 1, 2014 | 09:30 AM
cast.aluminum's Avatar
Default steering wheel ignition lock bolts?
I drilled those shear bolts off and tried replacing them with hex head type bolts, but, it didn't work. Does anyone kniw where i could buy those bolts? Or if honda carries them?
Old Dec 2, 2014 | 05:05 PM
got_no_sol's Avatar
Default Re: steering wheel ignition lock bolts?
civic steering lock bolts | eBay
Old Dec 6, 2014 | 07:17 AM
89civicdx's Avatar
you can remove the bolts with needle nose vice grip no need to drill and you can use hex bolt...try one from your seat rail see if that fit to test...i think the thread is 10mmx1.25 or 8mm. I use hex in my car
mikeyleed
Nov 6, 2013 11:53 AM
triumph_013
Jul 16, 2010 10:07 PM
pliskin679
Sep 14, 2007 06:57 PM
