Maybe they have change but years ago they came with recommended PTW clearance way too loose for the alloy they use. No need to run 0035-0045 with these. 002-0025 is fine and much quieter!
Now I got a B20B4 and GSR P72-2 with little work flow...
The Block: Honda CRV 98 stock sleeve 84mm x 89mm
* Supertech Pistons P4-H84-P5 5.5cc dome "12.5:1" / S2 Alpha Rods
* OEM Crankshaft / ACL Race Bearing Kit
* ARP Main Bolts / Oil Pump Type R
** Block Girdle BP for LS or B20
** Oil Pan Moroso 4qt. / Windage tray / Pickup tube for B18C1
* Water Pump Vtec / Timing Belt Blue-Gates Racing
* OEM Type R Oil Cooler / BWR Vtec-Converter Kit
** OEM CTR N1 Damper
The Head: GSR P72-2 with "slight port work" (I have some pictures, please I appreciate your comments on the port work is good or bad? )
* ARP Head Stud Kit / Cometic Head Gasket in 0.40"
* Supertech Valves 1000-Series / S2 Viton Valve Stem Seal Kit
** Supertech Valve Guide / ST Turbo Spring Kit / ST Aluminum Retainers w/Keepers in 10°
** Skunk2 Camshaft Pro-Series Stage 2 / S2 LMA
* Golden Eagle Adjustable Cam Gears / S2 IM Ultra Street / S2 IM Thermal Gasket / S2 TB Pro-Series 74mm
** P2R TB Thermal Gasket for 74mm
* Denso RDX Fuel Injectors 410cc / K-Tuned Hat-Top Fuel Injectors /GE Pro-Series Fuel Rail
* Walbro Fuel Pump 255lph / Hi-Flow Fuel Pressure Regulator
* OEM Type R 98+ Spec 4-1 Header / Full Catback Exhaust 3" in
The Trans: OEM S80
* OEM S80 ITR LSD 4.785 / The 4th gear is a S4C Trans
** Synchrotech carbon synchros
* ACT Street Clutch / ACT Flywheel
The Electronic: Hondata
* OEM Honda P28 with Hondata S300 v3
Basically I'm building a new engine, this is "my little big project", now as you can see I have some double asterisks on some parts, this is because even those I have not bought and some other I have some doubts; all other parts are in my room. I'm very anxious to buy I need to begin build it...
Supertech pistons work fine, I've got a few 250+ whp setups using them.
Originally Posted by hondaracing84
I run them and couldnt be happier. High compression 86mm B series 260+whp with no issues.
Oh, Thanks!!... You guys have great projects...
Originally Posted by whitesihatch
Great pistons, they come with a nice coating on them as well. If you want to spray it later.
Ok, perfect!!... I will consider...
Recently I just talked to Chris of the NoLimitMotorsport and made the purchase of the Supertech pistons, I bought the P4-H84-P5, hopefully arriving soon, guys thanks for all...
