D16A6 into '90 CRX HF, questions
Old Nov 30, 2014 | 10:25 AM
Euphorex's Avatar
Default D16A6 into '90 CRX HF, questions
Hello guys. I got a D16A6, full long block, that I want to put into my CRX HF. I've read from various sources that it will plug and play except for a sensor on the intake manifold. Is this correct?
Can I still run the HF ECU? Or do I need to put the HF Intake Manifold on the D16A6? I have the PM6 for the D16A6 as well.
Old Nov 30, 2014 | 05:26 PM
Pro-SeriesFab's Avatar
Default Re: D16A6 into '90 CRX HF, questions
The HF intake is tiny . . . keep the A6/PM6.
I would imaging the fuel and spark maps would be more aggressive and compensate better for the 4v head/cam than the lazy profiles of the 2v cam.
Old Nov 30, 2014 | 07:44 PM
BADFISH859's Avatar
yes swap is plug and play. You will need a PM6 ECU to take advantage of the D16A6, I have a couple I'd sell one for next to nothing.
Old Dec 5, 2014 | 04:54 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
Yes, the HF has an EGR ( exhaust gas recirculation) valve which the Si does not have.
HF ECU + Si intake manifold = check engine light... because of the missing EGR.
Use the Si intake manifold and Si ECU, problem solved. Just leave the EGR plug alone.
Old Dec 5, 2014 | 08:40 PM
york's Avatar
I also swapped to the Si instrument cluster - it has a higher red line. I believe you'll need a '90/'91 cluster.
Old Dec 9, 2014 | 08:44 AM
Euphorex's Avatar
Thank you guys. I appreciate it!
aemintgsr
Jul 8, 2008 07:54 AM
onlya1.1L
May 23, 2005 03:36 PM
cbrman
Feb 24, 2005 09:43 AM
iwouldHITit
Dec 29, 2002 06:24 PM
