ls with a b20 block?
hey!
has any one out there done a ls swap in to a eg with a b20 block.iwas going to do a h22a swap but after hearing some of the problems peps have had i was leaning to doing a ls with b20 block,but i dont know muck about this setup.if any of you guys know any thing about it let me know(price to install and buy,hp,ect).
help
help
wtf???????????? ls and b20 are 2 different motors . hrm yes many people have done ls swaps
SEARCH
http://www.hybridgarage.com for swap info
SEARCH
if i understand you correctly you wanted to use the LS head with a b20 block.. if thats what you were talkin bout then you would have the same thing as a b20.. since the b20 and the b18b(LS) share the same head...
what mr. del sol said was right...dont waist your $$ on buying an ls head and then buying a b20 long block....BIG MISTAKE, just buy the b20 long block and you'll be set, that is excluding a tranny, an intake mani(i would advise getting a ls skunk2 or a type r, but if you have the money just get the stocker ls), you would want to buy a different exhaust manifold, any b-series one would fit (CRV ones SUCK!!!), you need a new driver side mount(when i did my swap (ek coupe) i bought all new 99-00 si mounts, to get proper placement ie. now axel problems, this was one of the most expensive parts $704 from the factory), a starter(b-series), an ls ecu, flywheel(b-series), clutch, plus all kinds or misc. tranny parts (shift linkage, fork, stuff like that), and bolts (flywheel, and any other hardware you may need)...install will run ya about $800-1000+
mine cost around 5 g's but while the motor was out i got some head work done, and i have a gsr tranny so thats alittle more expensive then an ls or b16 tranny, and a skunk2 intake mani....so it will be like any other swap, $4000-4500 total
as far as HP goes, the b20b makes around 125-126 whp with intake and exhaust(obd1)
the b20z has higher compression and ive seen dynos of around 140-143 whp(obd1) with intake and exhaust...as far as trq goes, the b20b & b20z will make about 130 to the wheels.
GOOD LUCK
GOOD LUCK
I have the GS-R tranny on mine and it is great.
BTW the factory HP of the B20 varies with where it came from and what year the motor is
126hp (8.8 CR)
and
146 hp (9.6CR)
if you are curious about a stock B20 swap you can see my homepage.
126hp (8.8 CR)
and
146 hp (9.6CR)
the ls and B20 are the same if you cant get a B20 get a Ls and just bore it to be bigger! I am going to do a Ls/vtec i got the head and bottem but dont know what i want to do now! im waiting to see ! if i should get new internals or factory
b20 block has the bigger bore (and thicker sleeve, not just a rebore), and it also has an vtec oilpump, you can probably get an ls block + resleeve + swap in the vtec parts + you'll be str8. or buy a b20 longblock to save some hassle (just run a b18b manifold + cat and it bolts to the eg civic exhaust). just some food for thought :-D
-l8r
-l8r
-l8r
-l8r
b20 sleaves are weak. Just sleeve a cheap ls block.
