99 Accord, front end low speed collision. Bent Radiator Support.
Old Nov 28, 2014 | 05:21 PM
Adam Beck's Avatar
Default 99 Accord, front end low speed collision. Bent Radiator Support.
Looking to get an opinion on the damage to my vehicle and if the Radiator Support could be straightened out without replacing the entire radiator support.
I unfortunately cannot get the hood open. The latch has been disconnected or jammed, and the bolts that connect the latch to the radiator support are blocked from the bent hood. Otherwise I would provide some images from the top down.
Any ideas on how to get that hood open?
https://i.imgur.com/l6r1EOD.jpg
https://i.imgur.com/GWsMeDI.jpg
https://i.imgur.com/1A2Xo0G.jpg
https://i.imgur.com/FSvGC4q.jpg
https://i.imgur.com/LypkbGe.jpg
https://i.imgur.com/j78zqdx.jpg
Old Nov 28, 2014 | 07:22 PM
accordturb96's Avatar
Default Re: 99 Accord, front end low speed collision. Bent Radiator Support.
The latch cable should run right under that support and towards the driver side. unfortunately I dont think cutting it will open it because it is a loaded system. Looking at the diagram it looks like there are only one or two bolts that hold that entire latch to the support. Are you able to reach it via that front grill?
Old Nov 28, 2014 | 10:26 PM
toker2's Avatar
10 Year Member
I had pretty much the exact same damage done to my 96 in a similar accident. I was able to get the hood open (finally) by putting some weight on the highest part of the hood to flatten it out a bit. More specifically, I stood on it and jumped up and down a bit. YMMV
Old Nov 29, 2014 | 01:44 PM
Adam Beck's Avatar
Im unable to reach the bolts as they are completely blocked off by the hood.
Old Nov 30, 2014 | 08:26 AM
you will need to start getting creative. Jumping on it might work like toker said. If you flatten out the hump it should line the hood up for easier removal but no gaurantee
Silentz
Jun 8, 2018 05:56 AM
GraphiteMW
Feb 17, 2009 09:59 PM
Htounndea
Sep 3, 2006 02:51 AM
HybridHatchback
29
Jul 30, 2003 11:17 AM
