EJ2 Different front lcas
So ive had an unresolved handling problem for almost a year now gotten multiple alignments and replaced every front bushing but my car still pulls to the right.
i just crawled under my car to look for any noticeable bends or anything in my front lcas as a member on here suggested that could be a cause and what i actually found was the my driver side has an lca (the black part in the pic) with a sway bar mounting hole, and my passenger side has one without. the driver side one looks like an autozone replacement and the passenger looks oem but my question is would having i guess an ex one on the left and a normal one on the right cause the problem?
Did you ever get an alignment? They probably would've told you something, or the a piece of paper that tells you before/after specs of your alignment.
pliskin8
Mar 14, 2011 11:11 AM
