1990 honda accord for lights bulb question
these are the usdm foglights which i believe are the plastic ones right? the jdm ones are glass? well my question is. can i put hid's on mine without a problem. im guessing no which is why i haven't done it. don't want to melt the plastic cover on them. if not ill use those new led hid bulbs. homie has his on glass fogs with yellow hids and white hids he changes them every once in a while and his light output from the fogs is unbelievable
HIDs use less power than halogens. Stock fogs are usually 35-55w, HIDs are usually less than 35w. Less power means less heat.
That being said, don't be "that guy" with the HIDs in your fogs because you blind every single driver in oncoming traffic for no good reason. Fog lights already cause excessive glare in stock form but with HIDs you will be throwing a ton of light with very poor optics. DON'T DO IT.
The LED "fogs" would be fine but don't expect a meaningful gain in vision, they don't put out nearly as much light as a real halogen, and even if they did it would suffer the same problem as HIDs and would have terrible focus.
what are you talking about? lmao my homies fogs don't blind me what so ever!!! ton of glare with stock bulbs? wtf!!! lmao not even close!!! both hid kits he puts on don't give any glare like that. the only thing that "glares" more then his hid fogs are these new cars with hids projectors in them. like the s2000's bms' Mercedes etc.
On top of that, adding a high-output HID that has different optics than a halogen and tons of glare is inevitable. A HID capsule is a different shape than a halogen one so any housing designed for halogen will not focus HID correctly.
Don't take my word for it. See how many folks flash their lights at you. Or better yet, drive behind a couple police cruisers and see how long you get by without a ticket.
A fog lamp is designed to throw light in a wide pattern to help with extremely low speed driving in heavy fog. It's not designed to be used all the time, despite how others use it.
AhhNickk
Nov 30, 2009 12:12 AM
