wiring harness
Old Nov 25, 2014 | 05:24 AM
pnapolitano29's Avatar
Default wiring harness
hi i have an ef hatch with an obd2 b16 going in what wiring harness do i buy looking at rywire but not sure if obd1 or obd2
Old Nov 25, 2014 | 05:41 AM
innes887's Avatar
Default Re: wiring harness
You need your stock harness, obd1 ecu jumper (or obd0 b16 ecu), and an obd2 engine harness (for misc connectors)
Old Nov 25, 2014 | 07:43 AM
4drEF's Avatar
Keyboard Humorist
The Rywire harness you buy depends solely on what ECU you plan to run.
OBD1 ECU = OBD1 jumper
OBD2 ECU = OBD2 jumper
Old Nov 25, 2014 | 09:34 AM
So my stock harness is necessary?
Old Nov 25, 2014 | 09:44 AM
4drEF's Avatar
Keyboard Humorist
100% needed.
There is a cabin harness and an engine harness that, when combined, make a path for wires to go from the ECU to the appropriate sensor on the engine.
A different engine harness does not match up to the cabin harness.
The jumper harness you get from RyWire (and other places) reroutes the wires from the cabin harness to the correct location on the new ECU.
Old Nov 25, 2014 | 09:46 AM
Alright cool thanks i have cabin harness not stock motor one i can probally find one
Old Nov 25, 2014 | 11:27 PM
crx_si-r's Avatar
It would also help if you mention whether or not your car is a dpfi or mpfi.
Old Nov 26, 2014 | 07:16 AM
4drEF's Avatar
Keyboard Humorist
^^ there he is! pnapoliano - before you shell out money to the big name manufactures, have a talk with 'CRX Si-R'.
Zero disappointment!
Old Nov 26, 2014 | 07:30 AM
crx_si-r's Avatar
Check out my instagram c_zapien for pics or a dpfi to obd1 set up I am making. Started this on monday.
unautomobiled
Jul 28, 2010 06:05 PM
t1ny
Apr 18, 2006 11:45 PM
Racefiend
Jun 28, 2002 03:00 AM
