good price for brake 'upgrade'?
Old Nov 2, 2002 | 01:33 AM
J T*'s Avatar
Default good price for brake 'upgrade'?
my pads and rotors are worn, I've got a bad wheel bearing and a bent LCA, and I finally have some extra cash to fix everything...sorta.
So I asked Larry at 'Import Auto Salvage' how much for Integra brakes front and rear and he quoted me $475 for "everything I need to upgrade my civic brakes to integra specs, including master cylinder and prop valve..."
does this sound reasonable?
Thanks
Old Nov 2, 2002 | 01:43 AM
STEALTHMODECOUPE's Avatar
Default Re: good price for brake 'upgrade'? (J T)
hell yea..i jus might have to do that..now does that include all the parts to do the rear and front disc brake conversion??
Old Nov 2, 2002 | 02:43 AM
Mista Bone's Avatar
D Tranny Guru
well, just the front "knuckle swap" should only cost about $150-200.
Fronts do 90% of the work.
Stock 93 DX rear drums, (shoes are original!) PP valve, 15/16" MC, Teggy fronts.
Old Nov 2, 2002 | 03:51 AM
owen_the_soyboy's Avatar
yep. you can find cheaper but Larry Jr will make sure what you are getting is not some used up or broken parts, he makes sure the stuff he sends out is quality usable stuff. so go for it
you can really just upgrade the front to GSR spec (knuckle swap) an dthen later down the road go to a fastbrakes type of setup using ITR calipers over 93-96 Prelude VTEC rotors on those same GSR knuckles.
Old Nov 2, 2002 | 08:01 AM
J T*'s Avatar
Default Re: good price for brake 'upgrade'? (STEALTHMODECOUPE)
yeah, front and rear integra disc conversion.
I was just going to do the fronts, but I have a bent LCA in the back ( from a lil accident) and it's messing up my camber bad so I figure I might as well upgrade the rear while I'm at it.
...yeah and thats why I'm goin with Larry, I hear alot of good things about him.
Agguhnitus
10
Feb 14, 2012 02:04 PM
journeyquest
14
Aug 21, 2011 05:48 PM
streethondar
Jan 13, 2011 05:49 AM
remoer
16
Feb 13, 2007 06:14 PM
