89 civic si clutch change question
Old Nov 24, 2014 | 03:32 PM
flanker's Avatar
Default 89 civic si clutch change question
Hi Guys,
Sorry if this has been asked before, but I am about to change the clutch and according to the fsm I need to hoist the engine to unload the mounts. I have changed everything on this car except the clutch so it will be my first time. I have changed clutches before on other vehicles though.
So did any of you guys need to hoist the engine a bit when dropping the trans? Also I will be doing this on my driveway using jack stands. I also have a floor jack.
BTW why does the fsm say to remove the distributor?
Thanks
Old Nov 24, 2014 | 04:04 PM
v4lu3s's Avatar
RTFM
Default Re: 89 civic si clutch change question
its not too hard to smack the distributor cap and crack it when working in that area, and it sure makes more space to see what you are doing.
i have done changes with and without hoisting engine, instead using a jack under the engine with a block of wood between the jack and oil pan.
Old Nov 24, 2014 | 06:49 PM
flanker's Avatar
Thanks v4lu3s,
Maybe I will just get a second jack, been wanting to pick one up any how.
Old Nov 25, 2014 | 08:19 AM
v4lu3s's Avatar
RTFM
i have been wanting one forever, but i am also tall enough and strong enough I can lean in and pick the transmission up and put it on the engine. it does get old at times...
Old Nov 25, 2014 | 08:29 AM
flanker's Avatar
I'm strong enough (maybe) but definitely not tall enough 5'8'' to pull it out from the top. How on earth do you line the tranny up putting it back in doing it that way?
Also are there any odd sized bolts like 12 point that I might need a special socket for? I remember reading somewhere the bolts that hold the pressure plate are 12 pt. And should I get a rear main seal in case that one is leaking?
Thanks
paul anzalone
Honda Civic (2001 - 2005)
Oct 21, 2013 07:51 PM
black1987civic
Feb 28, 2008 03:25 AM
whagkangmakulet
May 11, 2003 08:57 AM
91 POS
Apr 28, 2003 08:01 AM
