D16Y8 Full Build - Oil Clearances
Old Nov 23, 2014 | 04:08 AM
CplNet's Avatar
Default D16Y8 Full Build - Oil Clearances
Hello everyone,
Im building a D16Y8, target 270-280whp... Eagles Rods + CP Pistons, Stock Block/Crankshaft and ACL Race Bearing
Its my first engine build and im having questions about my clearances, this is what i got so far:
http://www.nrteam.org/up/imgsimages/...1clearance.jpg
http://www.nrteam.org/up/imgsimages/...2clearance.jpg
http://www.nrteam.org/up/imgsimages/...d3clerance.jpg
http://www.nrteam.org/up/imgsimages/...4clearance.jpg
The mains clearances are good ?
#1 0,038-36
#2 0,038-36
#3 0,038-36
#4 0,038-37
#5 0,038-38
The rod clearances are good or too tight?
The #1 rod has a little more clearance than #2,3,4... (0,038 vs 0,025). It´s a problem?
#1 0,038-36 / 0,038-38
#2 0,028-25 / 0,038-34
#3 0,025-25 / 0,025-25
#4 0,025-25 / 0,028-28
(BTDC / BTDC+45º)
Thankz!
Old Nov 23, 2014 | 09:05 AM
1HGEJ2's Avatar
Default Re: D16Y8 Full Build - Oil Clearances
the rod clearence are to tight. best would be 0.035mm- 0.040mm
Old Nov 23, 2014 | 11:22 AM
CplNet's Avatar
Thankz for the reply.
That is was i was thinking too.. its better to loose it and shot for 0.0015" (0.035-40mm).
What i can do to get looser clearances?
Micropolish can do that or its too much for polish ?
Thankz
Old Nov 23, 2014 | 04:18 PM
m4xwellmurd3r's Avatar
Get some different bearings. I think they make acl race bearings that are thinner as well. If youre on the thinnest already, maybe have the rods honed a bit. I wouldnt wanna micropolish a crank
Old Nov 23, 2014 | 04:44 PM
CplNet's Avatar
Thankz for the reply!
They are ACL RACE..
And i dont trust machine shops here to hone the rods ;(
Im thinking in switch the rods bearings to OEM.. and target 0,038mm (0.0015) for rods..
And keep the acl race on mains 0,038mm..
Thats a good plan?
Old Nov 23, 2014 | 05:26 PM
Theres a stabdard acl race and acl race HX. The hx have more clearance
Old Nov 23, 2014 | 06:20 PM
CplNet's Avatar
i know..
but with the extra 0.001 i will have ~0.05mm of clearance.. too much i think
thats why im thinking going OEM and target 0,038-40max .. what you think?
Old Nov 24, 2014 | 02:28 PM
1HGEJ2's Avatar
HX are perfect! shim the oil pump and all fine!! d series have to thin clearence from factory. with looser clearence u havent a bearing failure. 0.05mm is perfect for b and d series
Old Nov 24, 2014 | 03:11 PM
CplNet's Avatar
Thankz for the input!
I think i will buy a HX set an measure..
I got a brown oem bearing today from a friend so i could measure all rods and then order oems from honda, but i dont know if will do...
Thankz
frostydc
Nov 6, 2017 11:40 AM
khmoe
Apr 27, 2011 10:17 AM
2muchboost2blow
Aug 10, 2010 06:23 PM
jakedoza
Feb 5, 2005 09:10 PM
