Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 civic ex brake problems
Old Nov 22, 2014 | 11:47 AM
Ofdems21's Avatar
Default 2001 civic ex brake problems
Hi I've changed the front brakes on my civic now the front drivers side is getting hot and smoking I've replaced the caliper and bracket and it's still getting hot and smoking any ideas
Old Nov 22, 2014 | 10:15 PM
toyomatt84's Avatar
Sanji
Default Re: 2001 civic ex brake problems
Did you clean the rotor off, then seat the pads properly?
Old Nov 23, 2014 | 04:32 AM
Ofdems21's Avatar
Yes
Old Nov 23, 2014 | 08:01 AM
toyomatt84's Avatar
Sanji
When you put the new caliper on, did you grease the sliders?
Old Nov 23, 2014 | 11:59 AM
Ofdems21's Avatar
Yes I did
It's got me stumped cause I've been doing this stuff for years and have never run into a problem like this
Old Nov 23, 2014 | 12:49 PM
toyomatt84's Avatar
Sanji
Yeah, this is a bit weird. I wonder if there isn't something wrong with the ABS module, to where you're getting inconsistent line pressures.
Old Nov 23, 2014 | 05:34 PM
Ofdems21's Avatar
I'll try unplugging it cleaning the contacs and try plugging it back in and see if that works
Old Nov 24, 2014 | 06:51 AM
Almighty-Si's Avatar
Jack the car up and try turning the wheel. If it's hard to turn, the caliper is locked up. Even though it's new doesn't mean it can't be bad. I've had it happen to me more than once especially using aftermarket calipers.
Old Nov 24, 2014 | 07:39 AM
Ofdems21's Avatar
Tried that still the same thing caliper is good
Old Nov 30, 2014 | 11:24 AM
spdracrm3's Avatar
bad brake hose? restriction inside can leave residual pressure (piston /pads wont retract fully)
Old Nov 30, 2014 | 01:20 PM
Ofdems21's Avatar
Yep I have even replaced the line still same thing
EFS463
Jun 17, 2013 05:58 AM
djowen
Mar 24, 2011 09:10 PM
NOTUNINGNONADA
Jul 21, 2010 09:03 AM
PabloDiablo
May 30, 2007 06:45 PM
sugarloafpkwy
14
Dec 4, 2005 07:31 PM
