2000 Civic fog light swith. Draining my battery?
Old Nov 22, 2014 | 02:38 AM
RuckRider2's Avatar
Default 2000 Civic fog light swith. Draining my battery?
hi guys i recently installed a fog lights and everything is working fine. its just the switch that came with the kit, im really worried that its always lit up even if the car is on off with the key removed from the ingnition its still lit up would that drain my battery?
Old Nov 22, 2014 | 04:12 AM
Former User's Avatar
Default Re: 2000 Civic fog light swith. Draining my battery?
If you're want help, you need to detail exactly how you wired the fog lights. Include pictures.
Old Nov 22, 2014 | 07:39 AM
tony_2018's Avatar
Fish Twig
You wired something directly to a constant 12v, no **** its going to drain your battery.
Old Nov 22, 2014 | 07:55 AM
andoxviii's Avatar
Is this an aftermarket fog light kit? I am going to assume that it is, considering the OEM version was discontinued a decade ago.
Those aftermarket switches are notoriously badly designed. I've seen where even a properly wired switch causes drain because it is shorting out inside the switch.
Old Nov 22, 2014 | 08:01 AM
RuckRider2's Avatar
yeah its the aftermarket ones, i followed the instructions here
https://honda-tech.com/honda-civic-d...iring-3076707/
Old Nov 22, 2014 | 08:43 AM
Post pictures of your wiring job.
Emccullough3
Sep 25, 2017 08:40 AM
Elderly Iron
Jun 5, 2017 04:19 PM
sexyblack973
Jan 13, 2014 07:46 AM
tjin83
Dec 3, 2006 07:33 AM
