CA 1996 Nissan 240sx with goodies
Haven't post here in a while. Testing Water
1996 Nissan 240sx 5spd base model
Super cold A/C and hot heater
Clean title 197k miles on chassis and motor. Original Miles
Engine:
stock ka24de obd II
Recently replaced with OEM parts from Nissan, water pump, thermostat, alternator and z32 fuel filter. Front main seal. New NGK iridium spark plugs, wires distributor cap and rotor.
Sonic motor aluminum radiator. GKtech fan blade.
K&N drop in filter
RSR ex-mag black piping cat back exhaust
Drivetrain:
ACT heavy duty pressure plate with street disk clutch, baker precision clutch steel braided clutch line. Driveshaft shop 1 piece steel drive shaft.
Kaaz 2-way LSD I used Kaaz fluid every 3000 miles
Brakes:
z32 30mm aluminum brakes front with new rotors and portifield rs-4 pads. Stock s14 rear with new rotors and bendix ceramic pads. Steel braided brake lines
Suspension:
JIC Magic fla-t2 coilovers
Tien inner/out tie rod
Kazama tension rods
PBM g1 rucas
ST front/rear sway bars
New Energy suspension rear subframe and diff bushing
Tanabe front/rear strut bars
Wheels:
5lug conversion
Varrsteon 17x9 +22 front 17x9.5 +30 rear
Interior:
Full stock interior 7/10 condition. 1 crack on dash
PBM shift ****
Exterior
Painted lavender metallic
Origin-lab stylish aero
Nissan rain guards
Dmax tail lights
Circuit sport clear corners and side marker
CON:
BLOWN HEAD GASKET
BOUGHT OEM HOOD, SO ITS DIFFERENT COLOR
I am a medical student and don't have time to fix it due to almost impossible to finish bunch of homeworks and studying. I don't even have time to go out either.. I am not in a rush to sell. IF NOT, I LIKE THIS CAR A LOT SO I DON'T MIND KEEPING THIS CAR UNTIL I FINISH SCHOOL AND FIX IT.
$4000 as is
$3500 without wheels
Keep negative comment to yourself, thanks Pink slip in hand ready
text 714 728 3683
Engine:
stock ka24de obd II
K&N drop in filter
Drivetrain:
Brakes:
Suspension:
Kazama tension rods
PBM g1 rucas
Wheels:
5lug conversion
Interior:
PBM shift ****
Exterior
Nissan rain guards
Dmax tail lights
CON:
BLOWN HEAD GASKET
$4000 as is
text 714 728 3683
Please see here: Honda-Tech - Announcements in Forum : Honda-Tech Marketplace
blue1.6eg
Apr 18, 2015 01:34 PM
