92 civic si - intermittent taillight/corner lights/cluster lights
Old Nov 20, 2014 | 01:34 PM
swizz977's Avatar
Default 92 civic si - intermittent taillight/corner lights/cluster lights
92 civic si when i put the headlights on they work but the front and rear corners cluster and taillights dont go on
however the brakes and headlights do work
now this is happening on and off any ideas?
Old Nov 20, 2014 | 04:42 PM
Former User's Avatar
Default re: 92 civic si - intermittent taillight/corner lights/cluster lights
fuse 19
Old Nov 20, 2014 | 04:50 PM
swizz977's Avatar
Default Re: 92 civic si - intermittent taillight/corner lights/cluster lights
ok ill check that but i didnt think it was a fuse since it was intermittent
Old Nov 20, 2014 | 04:52 PM
Is it still intermittent? If so, test the light switch on the steering column.
Is fuse 19 loose?
Old Nov 20, 2014 | 05:24 PM
swizz977's Avatar
the light switch? if it was bad would the headlights still work?
Old Nov 20, 2014 | 05:49 PM
They are separate contacts inside the switch. Take a look in the service manual.
Old Nov 22, 2014 | 06:45 PM
weatherall123's Avatar
I had a similar issue on my 1994 Honda Civic SI. My cluster, turn signals and clock illumination would randomly stop working. It was an intermittent issue that seemed to happen more so on hot days as well as whenever I used my turn signals.
As RonJ@HT pointed out, a loose fuse 19 was the culprit.
Hectic937
Jun 30, 2015 11:36 AM
1baddturbosi
Dec 19, 2006 02:48 PM
1baddturbosi
Dec 15, 2006 06:52 AM
timntam
Feb 9, 2006 10:01 AM
InJ3cted
Jun 26, 2005 09:18 AM
