Starting and dying problems?
Old Nov 20, 2014 | 10:45 AM
CeeRichh's Avatar
Icon3 Starting and dying problems?
So I have a 98' Honda Accord Lx, 5-speed, 4-cylinders, with vtec. I had this problem where sometimes it would start and then other times it wouldn't, it would turnover but just wouldn't catch. I changed out the main relay because I was told that that could be the issue. Now there is a new main relay, the car starts every time but then turns off seconds after. With the old main relay in when it started it wouldn't turn off , so why would this be happening with a new relay? What else should I look int that could be the problem?
Old Nov 20, 2014 | 05:58 PM
stevenbr549's Avatar
Default Re: Starting and dying problems?
I remember there being a recall on ignition switches, but I think that was for like '94-'97 models. Still though, maybe something you'll want to check.
And check the main relay connector for pin fit, corrosion, etc.
r1ch1e
Nov 15, 2008 06:12 AM
ninjarich2
May 11, 2007 12:51 AM
DeviousCTR
Jun 28, 2006 03:43 PM
silentblackhat
Jun 10, 2005 07:55 PM
